fiesta st170 turbo
Re: fiesta st170 turbo
i saw nearly all your runs mate and how ever bad you feel the car was flying
- FRSJON
FRSJON :i saw nearly all your runs mate and how ever bad you feel the car was flying
you should of poped over mate
shame the gearbox was costing me so much time and terminals had a look at the data logs, every gear change was over 0.8sec's ,thats 1 second lost on the throttle !! doesnt sound like much but i was pulling 123mph in 12ish seconds so thats 10mph'ish ever second !!!
f**k it theres allways next time ,happy it is making some good power and didnt brake
that little blue mk2 fezz was mint and car of the show imo
- crazycage
nice one mate, just spied your inlet on the old ebay. you having a change of inlets?
- cowie20
cowie20 :nice one mate, just spied your inlet on the old ebay. you having a change of inlets?
no mate i have a few of them lol
- crazycage
ha ha good stuff, any old exhaust manifolds kicking about?
- cowie20
They are slow gear changes! And low boost! Bring on the slick shifts and the sort of boost it can run A promising starting point once again matey! What ECU are you on? I'm guessing you could do with a bit of help from it in the lower gears if you're going to start running 1.5+ bar, or will you just use your skillful trainer?
heeman10 :They are slow gear changes! And low boost! Bring on the slick shifts and the sort of boost it can run A promising starting point once again matey! What ECU are you on? I'm guessing you could do with a bit of help from it in the lower gears if you're going to start running 1.5+ bar, or will you just use your skillful trainer?
ecu is ms2 extra, i have a two stage boost switch on the steering wheel but my trainer's not to bad lol.
- crazycage
Hehe good lad
- crazycage
Awsome pics mate
- creator
Sounded great at central day
Bit late but congrats on the feature mate. were great pics
- Ram
Ram :Sounded great at central day
cheers mate ,look forward to seeing your's
- crazycage
- crazycage
- crazycage
sweet fab work
- SEG1
- GavStyli
- Your car: Fiesta Turbo
thanks people will be making one for the engine side soon . drove the car today and its miles better.
also having a new rear can made for the car the one thats on it now is 6" round by 16" long and its way to loud for road use the new one is 6"x12" oval 24" long !!! should be much better
also took off the bonnet spacers was getting gassed in the car
will have pic's of the can mid week.
- crazycage
good work gary, do you think with your spec is making 400 @ the flywheel? is that with your own head ?
- andymcd
looking good mate,cant belive you have ground away some of your bufty engine bay lol,that mount looks spot on tho mate.hows the gearbox now does it still need looking at or have you sorted it mate?
- creator
andymcd :good work gary, do you think with your spec is making 400 @ the flywheel? is that with your own head ?
its about 370hp i would say mate and yes its on the head i ported and only running 19psi so its doing the bizz
when i sort the box i will fit my new actuator and up the boost to 25-26psi and over 400hp
- crazycage
creator :looking good mate,cant belive you have ground away some of your bufty engine bay lol,that mount looks spot on tho mate.hows the gearbox now does it still need looking at or have you sorted it mate?
box is still f**cked mate , when i say f**cked it drives fine just the faster you try to change gear the more it locks you out im having a new one built with ratios to suit what i want from it
should see a 130mph terminal when its all done tho
- crazycage
should see a 130mph terminal when its all done tho [/quote]
nice one mate sounds sweet is a company building this new box then? or you and your mates? 130 terminals that will upset alot of people im sure lol cant wait,will it be built and in for classic day mate?
- creator
creator :box is still f**cked mate , when i say f**cked it drives fine just the faster you try to change gear the more it locks you out im having a new one built with ratios to suit what i want from it
nice one mate sounds sweet is a company building this new box then? or you and your mates? 130 terminals that will upset alot of people im sure lol cant wait,will it be built and in for classic day mate?[/quote]
im not doing the box lol ,getting a local trasmission place to re build it but from 3 different mtx boxes
- crazycage
- crazycage
nice one mate that looks spot on,will the new gearbox be ready in time for classic day mate?
- creator
well the monday after central day saw the end of my daily car was to unreliable lol so it got scrapped have been using the fezz ever since still gets hammerd hard every day if the breaks i will have a two hour train trip to work and back
done loads of little jobs but not worth telling you lot about .
its going in for its mot on tues morn so thought it was about time i changed the rear bumper .
when i bought the shell it came with a chavy mk4 rear with a big gay splitter so that was binned off for the mk3 rear bumper but with the number plate on it and no light it would fail the mot .
just fitted this rear but cut a bit about 4" by 26" off the bottom as my new exhaust sitts on the wrong side lol.
and fitted 4 new toyo t1rs not as good as the 888s but better than i thought . with the miles im doing week in week out and the price of the 888s these days i pulled them off.
- crazycage
looks good mate, how are the mounts holding up to use? what boxes are you using to make the new mtx? any idea of the 6 speed mondeo diesel ratios/fitment or are they the same as the sty170?
- dangerousdave
dangerousdave :looks good mate, how are the mounts holding up to use? what boxes are you using to make the new mtx? any idea of the 6 speed mondeo diesel ratios/fitment or are they the same as the sty170?
mounts are great focus diesal final drive with my focus rs gear set.
- crazycage
just got back from the mot , failed on near side head light to high and the off side track rod end not bad for a 20 year old s**t box
- crazycage
crazycage :just got back from the mot , failed on near side head light to high and the off side track rod end not bad for a 20 year old s**t box
prob the only thing you aint changed! def aint a s**t box ether
- dangerousdave
Nice one mate on the Mot.
Hows the new box?
Whens the next outing in anger!!
Hows the new box?
- luca
dangerousdave :crazycage :just got back from the mot , failed on near side head light to high and the off side track rod end not bad for a 20 year old s**t box
i know mate but its just what a few of us call it lol.
the track rod ends are 14 months old
two new ones on at the weekend
- crazycage
luca :Nice one mate on the Mot.
Hows the new box?
i hate mot's mate always think its going to be bad.
i have the diesal box but havent got a car to run round in the the mo so cant pull mine off the road to take the box out .
but using it every day has made me sort all sorts of little jobs that i can never be arsed doing
ill be at ford fair doing the 0-60 again got a 5.03 to beat
then mabe a rwyb not long after
- crazycage
Sounds good mate, will see you at Ford fair im going for some track fun and more than likely have a dabble at the 0-60
I have ??.?? seconds to beat
- luca
nice one mate,im glad your going to ford fair again this year,you going to be parked up in the fast ford stand again?
be good to see what difference you get on the 0-60.
be nice to see you having a bash on the o-60 to luke be nice to see the difference between both cars
- creator
