fiesta st170 turbo
Re: fiesta st170 turbo
dangerousdave :been looking at the megasquirt 2v3 on diyautotune.com in the states, look very good and a reasonable price too, ill be lookin closly at this one as i may sell my ofac, loom and superchip to get one
thats what i have and two of my mates run it its really good.
- crazycage
i have heard its more friendly on the road than the gotech and even the more expensive omex etc.. definatly want to see you get good results from it tho. they even come with a built in 21psi map sensor dont they?? how hard are they to map yourself?
ill be getting one in the new year if i can get a good price for my frst one!
keep us posted buddy
- dangerousdave
dangerousdave :i have heard its more friendly on the road than the gotech and even the more expensive omex etc.. definatly want to see you get good results from it tho. they even come with a built in 21psi map sensor dont they?? how hard are they to map yourself?
yes it comes with a built in 21psi map sensor but so does the gotech , but the ms2 is way easier to map IF you can map that is!! and its a lot more refined than the gotech just my opinion tho .
hope to get into the very low 12s if not a high 11 next year and all on a home build and mapped car on a small budget
- crazycage
thats what im after mate, obv not as quick but a nice reliable 180-200 bhp with the decomp plate and t3 would be nice
- dangerousdave
crazycage :So_SiMpLe_ :Great car mate!
How many hp you got now?
What's the 0-60 time?
i won the fwd class at ford fair this year with a 5.03 @1.2bar boost and a 5.24 @0.9bar boost with about 300hp and only had them two runs it was far to busy
engine is now doing about 350hp but maxed out my injectors ,ive got some bigger ones and a new management system so will be on the dyno about march next year hoping for 370+hp
But how does the car have good grip?
Doesn't it start wheel spinnig like will never ever stop?
What about cornering? Is it good? aceleretion while cornering?
- So_SiMpLe_
mtx gearbox decent drive shafts rose jointed botom arms and someone who knows how to drive there own car
- creator
So_SiMpLe_ :But how does the car have good grip?
You would be surprised what a decent LSD does for traction. Even with standard lower arms and normal sports road tyres I could pull away from Rawli's 150bhp FRST with ease in my car when it was only 170bhp, because he was spinning away and getting nowhere - on 17s! Moving on to rose jointed lower arms and Toyo R888s, I could fully plant it in second gear with no wheelspin on a good surface. That was with 200bhp, 245lbft and a stripped interior. It flew I have a mate with a 205 Mi16 that spins as soon as you try to accelerate in the lower gears, and had a customer with a 320bhp Civic Jordan 1.6 Turbo. He had the same issue. Both these cars are wasted because they have good power:weight ratios, but an open diff, so all that power is wasted. The ability of an LSD-equipped car to accelerate through, and out of corners is a world apart from an open diff-equipped car. Rawli thought I'd converted mine to 4WD the first time he tried to follow me through a big open roundabout Squat and go!
So_SiMpLe_ :crazycage :So_SiMpLe_ :Great car mate!
i run on toyo r888s all year round, i also have a good diff and suspension but thats it nothing fancy
it will spin up in 1st and 2nd but still pulls you forward as its spinning, my 5.03 run wheel spun through the first two gears to hit 60mph my 5.24 i tried tuning the boost down so it didn't spin up in 2nd gear but the time was slower.my car has never spun up in 3rd gear ever
- crazycage
Are you still running standard 2.0 130 spec cams mate??
- scouse-sambo
scouse-sambo :Are you still running standard 2.0 130 spec cams mate??
yes mate
- crazycage
- GavStyli
- Your car: Fiesta Turbo
Trigger :nice 1 dave, keep it up
whos dave
- crazycage
yhink hes keeping with his trigger theme lpl
- dangerousdave
well as you aint got a name, might aswell make one up for ya dave!
crazycage :Trigger :nice 1 dave, keep it up
whos dave
- GavStyli
Trigger :well as you aint got a name, might aswell make one up for ya dave!crazycage :Trigger :nice 1 dave, keep it up
whos dave
dave's fine then mate
- crazycage
the best name out there
- dangerousdave
dangerousdave :the best name out there
lol garys not to bad tho
p-s will get a pic up of my new top mounts fitted later today.
- crazycage
well i got out there for a bit this weekend and fitted the top mounts there a direct fit you just have to drill two 8.5mm holes for the bolts ,ive just used some s**t ones for now till i paint the bay then ill fit some nice cap head ones
also welded in some new mounts for the engine and box there was just a tad to much movement when hard launching at the pod so fited the focus engine mount on the inner wing and put a mtx rear box mount on the front of the box aswell
so just need to find some time to clear the loom ect out the bay ready for the seam sealer and paint
- crazycage
looking good mate carnt wait to get mine to you.lol glad you like my new shell bet you carnt wait to get a grinder to it.lol would you prefer to have my shell before the engine goes in or what cheerz fella just drop me a txt if you wana discuss it further cheers pal
- andyb-rst
have you not got a front engine mount on mate? that would prob help quiet a bit! thats my next job on mine after the inlet is sorted!! them top mounts are looking good too buddy! are they sperical bearings then instead of the old rubbers?
- dangerousdave
dangerousdave :have you not got a front engine mount on mate? that would prob help quiet a bit! thats my next job on mine after the inlet is sorted!! them top mounts are looking good too buddy! are they sperical bearings then instead of the old rubbers?
blacktops dont have the front mount and dont need them mate i have just gone a bit over kill and yes the top mounts replace the standard rubbers ,will make a big difference to my set up
- crazycage
didnt realise it only had the 1 mount!
you will have a near solid front end then now! lol theres no excesive movement now bud! lol
- dangerousdave
dangerousdave :didnt realise it only had the 1 mount!
focus only have one engine mount and two gearbox mounts i now have two engine mounts and three gearbox mounts ,i could of fitted up-rated mounts but there really hard and cost a fair bit lol and my car gets used a lot on the road so dont want hard mounts anyway.
- crazycage
Drill large holes all around the rubber of the mount, then fill the holes with tiger seal
- Ruishy1
looking good gary, whate is on those top mounts?
- andymcd
andymcd :looking good gary, whate is on those top mounts?
cheers, what do you mean whats on them ?they fit inside the turret all you can see is the bearing really
- crazycage
Rs1800 Fiesta zetec runs x 2 engine mounts.
- luca
andymcd :price on them?
im not sure what they cost im friends with tony @909sport ,i couldnt tell you what i paid for them or the bottom arms .just drop him a email mate
- crazycage
- crazycage
nice work mate, bay will look spot on with slap of red. got inlet fitted and frst throttle body on, how did you fit a throttle cable support bit? i fitted one from fiesta but hits my bonnet.
- cowie20
Nice work mate
- Dave G fsi
- Your car: Mk1 FRS and FRST
cowie20 :nice work mate, bay will look spot on with slap of red. got inlet fitted and frst throttle body on, how did you fit a throttle cable support bit? i fitted one from fiesta but hits my bonnet.
i used a fiesta one but cut it down ill take a pic of it for you
- crazycage
that would be spot on cheers, i was thinking of bending it down but wasnt sure. cheers
- cowie20
just finished painting the bay will post pic's up soon .
- crazycage
