fiesta st170 turbo
Re: fiesta st170 turbo
andymcd :looks good mate, what turbo are u using?
gt2871.86 trim 56. (the biggest 2871) hoping to max it very soon...
- crazycage
Whens the next pod trip mate ?
- luca
luca :Whens the next pod trip mate ?
central day
- crazycage
crazycage :luca :Whens the next pod trip mate ?
central day
cant wait,going to be awesome...
- FRSJON
- crazycage
- crazycage
awsome thread mate, such an inspiring build, really shows what can be done to a fiesta
btw i got a nice and clean header tank if you throw me a £7 ill pop it in the post for you soon as
couldnt clean the tank need a new one
someones been busy lol looks spot on mate.dash looks sweet been hearing really good things about that company and from the pics i can see why.
you been out mapping yet then mate?
- creator
creator :someones been busy lol looks spot on mate.dash looks sweet been hearing really good things about that company and from the pics i can see why.
out tonight mate
- crazycage
had it out for its first run since oct last year, on new injectors and ecu ect and all is fine boost upto 0.6bar more to come and soon
- crazycage
sounds sweet mate weres the video? lol
- dangerousdave
Looking good mate
- Dave G fsi
- Your car: Mk1 FRS and FRST
Are you strapping to the dyno to see what power she is running at.
- luca
luca :Are you strapping to the dyno to see what power she is running at.
yes mate will be on a dyno as soon as the boost is back to where i want it lol .
but f**k me it flys on .6 bar
p-s not that im that bothered what it makes as long as its 350+
- crazycage
350+ hell yeah
- cowie20
nice one mate sounding all good so far
- creator
forgot to say im testing a new head gasket its a ford part and 1.8mm thick has dropped my cr from 8-8-1 down to 8-3-1,will see if its any good but it should be as its basicaly the same as the focus st and rs but a little thicker
- crazycage
whats it off then mate..
- luca
hey mate did you fit the sub frame back on your car? asking as i cant fit mine due to exhaust and when i looked back at your pictures when you had the st170 engine it doesnt look like you have fitted it.
- cowie20
luca :whats it off then mate..
its just a 2.0l zetec /st170 gasket that ford use when the head and block have been skimmed a bit too far ,a friend in fords told me about it, not Manny people know there is such a gasket i needed the part nomber to get it as the tech gay didnt know about it lol.
- crazycage
cowie20 :hey mate did you fit the sub frame back on your car? asking as i cant fit mine due to exhaust and when i looked back at your pictures when you had the st170 engine it doesnt look like you have fitted it.
do you mean the brace that links the wishbones then no i havent tryed to fit it but i will in the summer
- crazycage
yeah the brace mate, am thinking cutting mine and making a new bit to go under exhaust, exhaust is bang on in line with it or do you think i could just space the brace down with 1" steel blocks between the brace and floor, if you know what i mean.
- cowie20
would that not put more stain on the bolts ??
thinking about it so long as the bolts and threads are good nick should be ok
just use some washers or some 15mm thick sheet metal
- HCS PIMP
yeah true, ive used just solid brass spacers about 15mm. its temp tho as its all i had, ill get 15mm bar and weld it to the brace and re drill the holes. should be solid enough
- cowie20
Ive retained the lower brace between wishbones and have 1inch alloy spacers.
There is no extra strain on the bolts.. aslong as you use longer high tensile bolts.
- luca
you thought could be a problem with the waste gate or actuator causing the low boost ?? or maybe the map sensor
- HCS PIMP
HCS PIMP :you thought could be a problem with the waste gate or actuator causing the low boost ?? or maybe the map sensor
i havent got a boost problem mate i always start mapping with the lowest boost i can run then start turning it up till its where i want it .
- crazycage
you managed to get more mapping in mate? has the boost been pushed up yet?
- creator
no mate not yet im in no rush i have 6 weeks till central daycreator :you managed to get more mapping in mate? has the boost been pushed up yet?
- crazycage
mines is up and running now mate, cant get rev counter to work, i connected wire that went to ofab ecu to the gotech, but doesnt work? you any ideas as you were running gotech before was you.
- cowie20
cowie20 :mines is up and running now mate, cant get rev counter to work, i connected wire that went to ofab ecu to the gotech, but doesnt work? you any ideas as you were running gotech before was you.
ahh cool mate made up for you. take the wire from the clocks, iirc its the green one and run it too any of the two outside wires on the plug for your coil pack ,thats how mine has been for years
- crazycage
crazycage :no mate not yet im in no rush i have 6 weeks till central daycreator :you managed to get more mapping in mate? has the boost been pushed up yet?
6weeks god i need to keep track of time lol though i had longer than that haha,do you know what boost your going to be runnin then mate or are you just going to keep increasing till you cant go no more? lol
- creator
nice one mate will do that today. cheers
- cowie20
