fiesta st170 turbo
Re: fiesta st170 turbo
Excursion :Looking good mate. For more equal cylinder filling the entry into the main plenum from the feed plenum should be on a taper – starting out wide at the TB end and narrowing towards no 4
cheers. the plenum feeding the main plenum is a cone didnt you see you pic of the cvh one i made ? its a few posts up .
- crazycage
crazycage :Excursion :Looking good mate. For more equal cylinder filling the entry into the main plenum from the feed plenum should be on a taper – starting out wide at the TB end and narrowing towards no 4
Like this mate
The area over each inlet port should be a 1/4 less than the previous port
Maybe the picture doesn't show the angle too well.
epic stuff going on mate i'm glad to say i own one of your inlets. very good at what you do. like your new engine mount wish i had thought of that will be b it hardcore for me thought you still going be use this as ya daily once its fixed?
- leighk2010
Excursion :crazycage :Excursion :Looking good mate. For more equal cylinder filling the entry into the main plenum from the feed plenum should be on a taper – starting out wide at the TB end and narrowing towards no 4
Like this mate
didnt know thats what you ment mate
the mountune wrc inlet that i have is a twin plenum like plenum i am building and the slot is the same size all the way along
the jenvey turbo inlet is very similar too.
- crazycage
leighk2010 :epic stuff going on mate i'm glad to say i own one of your inlets. very good at what you do. like your new engine mount wish i had thought of that will be b it hardcore for me thought you still going be use this as ya daily once its fixed?
no i wont be using it every day but most days
i am hoping for it to be taxed 1st of june
- crazycage
SANTA POD BABY!
- luca
The need for tapering down will certainly be lessened in a double plenum setup, compared to single plenum, but it's probably still there to a degree. I could've run a flow simulation if I had Solidworks to hand...best get to grips with simulation on Inventor!
luca :SANTA POD BABY!
i will be having a go mate. got my eye on a 130 terminal
when you running next?
- crazycage
heeman10 :The need for tapering down will certainly be lessened in a double plenum setup, compared to single plenum, but it's probably still there to a degree. I could've run a flow simulation if I had Solidworks to hand...best get to grips with simulation on Inventor!
a friend of mine does all the cfd for me ,but i am thinking of having a go myself ,just need to get it onto my comp
- crazycage
i have also had a new box built with standard focus rs ratio's as i didnt really like the last one with the 3.41 fd fitted
and put a KAAZ plated lsd in there just to see if i like it better than my atb diff.
- crazycage
crazycage :i have also had a new box built with standard focus rs ratio's as i didnt really like the last one with the 3.41 fd fitted
Did you have the 2.0 ratios with 3.41 FD?
What didn't you like about it?
Excursion :crazycage :i have also had a new box built with standard focus rs ratio's as i didnt really like the last one with the 3.41 fd fitted
it is a focus rs box with the 3.41 fd fitted .
it geared the car for over 180mph , i only fitted it so i could hit 130+ in 4th gear . top speed is not my thing
its hard to explain but just sort of took a little edge of how torquey it was low down part throttle low boost round town if that makes sence.
it made more boost lower down but didnt pull harder for it ,made it feel a little laggy but the data logs show it wasnt
- crazycage
crazycage :luca :SANTA POD BABY!
Not sure actually mate, wont be at Classic Ford show in it though.
Im enjoying trackdays too much, but will try again at Pod sometime.
- luca
crazycage :Excursion :crazycage :i have also had a new box built with standard focus rs ratio's as i didnt really like the last one with the 3.41 fd fitted
Ahh OK. FYI the FRS box is just a 2.0 box with the diff and shot peened gears.
I'm making up a 3.41 box also the other - is it 4.21 or something?
3.82 mate
- crazycage
crazycage :took a little edge of how torquey it was low down part throttle low boost round town
It's all about the 11 second car that feels good around town.
- crazycage
Looks bloody sweet that mate now get it finished and mapped
- creator
Absolute quality work there mate - some great unique mods going into the car!!
I will be interested to see what benefits the toy car gives to the inlet
Si
Si
- SiST
- crazycage
looks great, ill admit my ignorance though, i done know what the twin plenum system does and what its advantages are
jonyb4 :looks great, ill admit my ignorance though, i done know what the twin plenum system does and what its advantages are
its all about equal air distribution
- crazycage
- crazycage
all looking good and im sure will prove itself very soon..
- FRSJON
good job mate very jealous must say
- leighk2010
made a new oil catch/separator tank with a return to the sump ect it's stainless steel but it cost me nothing and i got paid time and a half to make
just need a bracket to mount it and a coat of paint
still waiting on the billet fuel rail to turn up so i cant finish the inlet off off out to fit the wastegate
- crazycage
Nice welding! Fancy doing another? I will pay you, obviously.
Excursion :Nice welding! Fancy doing another? I will pay you, obviously.
no problem, how manny inlet/outlets do you want ect ? and if you want i can build it how ever you want if you have a design in mind.
- crazycage
- crazycage
i could do with one of them inlets
- SEG1
Nice pipework there Gary
When you hoping to have ready?
- luca
Looks spot on dude new boost pipes sweet
- creator
luca :Nice pipework there Gary
will be running next weekend
- crazycage
