fiesta st170 turbo
- Smo
Re: fiesta st170 turbo
Excursion :Dairy tubing?
Looks great!
no thats only 1.5mm wall this sch10 pipe a little over 3mm wall .will stand upto the heat much better and shouldnt crack.
still got the external wastegate to pipe into it
- crazycage
- SEG1
Awsome work as usual gary looks brilliant mate
Hard to tell from pics on my fone but is there enough room for top rad pipe to thermostat housing? Cant wait to see some more progress mate
- creator
creator :Awsome work as usual gary looks brilliant mate
tbh its closer than id like but if its a prob ill put a cvh stat housing on it
cant really do any more till get some parts in the new year
- crazycage
Looking good tht Gary
- luca
Looking good, is the car used fro Drag, Track or both?
If it was me i would mount the turbo in the way like are friends over the pond do and like Andy Speck Tigra
- freak power
great job, how on earth will you manage to weld that up?!
i did try it like that but i couldnt get a filter on the turbo thats why i went the way i did.and just to be different
car will be used on road strip and track
- crazycage
jonyb4 :great job, how on earth will you manage to weld that up?!
easy really ,put plenty of good tacks on it, then brake one full runner off from the head flange and from the collector, weld it on the bench ,polish it ect then weld it back on and start again
- crazycage
What sort of tig torch are you using as when you get to the collector its going to get tight
I use a WP26 flex head, small back cap, No7 Gas lens and the tungsten stuck out i still find it tight
- freak power
freak power :What sort of tig torch are you using as when you get to the collector its going to get tight
i have a few different torches i can use,but my er9 with a flexy head will be fine .granted it will get tight but it wont be a problem .
im coded in tig welding stainless pipe in every position
- crazycage
aah clever just bit of a jigsaw puzzle getting them to sit back on the flange
- crazycage
good job you have done there mate. How long have you been in the welding game are you coded in tig because the quality is amazing fella. My old man is spying over my shoulder and commenting that this is some very good work and he has been a welder for 40 years. He used to weld gas mains and all sorts and said you are very talented.
- rsturbonutter
- Your car: Fiesta RS turbo
rsturbonutter :good job you have done there mate. How long have you been in the welding game are you coded in tig because the quality is amazing fella. My old man is spying over my shoulder and commenting that this is some very good work and he has been a welder for 40 years. He used to weld gas mains and all sorts and said you are very talented.
im a yung 30 mate been doing it 13+ years. yes im coded in tig aswel as mag/mig .
thank your dad for the kind words
- crazycage
nice manifold gary,the welding on it looks spot on, are there any other bits you want to do on yours? looks like this year is going to be a good year for mk3 fiestas
- robp-tt
robp-tt :nice manifold gary,the welding on it looks spot on, are there any other bits you want to do on yours? looks like this year is going to be a good year for mk3 fiestas
theres lots i'd like to do but i just dont have the time
soon as the external gate is fitted im doing the new down pipe then onto the dry sump
- crazycage
Very nice work!! I have a manifold that was supposedly welded by a professional exhaust specialist, and the quality of work doesn't even remotely come close to what you've done there!
- Smo
Just a quick question. When you have a manifold of this type with the turbo over the gearbox so to speak what down pipe do you use
- rsturbonutter
rsturbonutter :Just a quick question. When you have a manifold of this type with the turbo over the gearbox so to speak what down pipe do you use
there is no off the shelf down pipe no problem for me tho
- crazycage
You can make one for me then lol
Awesome work your doing mate
- snoopaloopa
- Your car: ford
.a true masterpiece.
- SEG1
- crazycage
- crazycage
shall i assume thats just a mock up turbo
being that its internaly wastegated
whats the plan 30 / 70r ???
- HCS PIMP
HCS PIMP :shall i assume thats just a mock up turbo
no mate ,its my gt28 . i will be welding the the old wastegate shut
when this turbo s**t its self i will get a gtx3071.82
- crazycage
could you not just change the exhuats housign the remove the wate gate
- HCS PIMP
crazycage :HCS PIMP :shall i assume thats just a mock up turbo
That would be epic- I have just got one of those turbos turning up tomorrow and can't wait.
Manifold looks really good as well
- SiST
- freak power
- crazycage
