fiesta st170 turbo
Re: fiesta st170 turbo
Looking very nice fella. Don't look like you got much room for a bigger servo though
- rsturbonutter
- Your car: Fiesta RS turbo
top effort here mate
- RS rob
- crazycage
love it !
- FRSJON
looks gd mate
- fiestarsturboblack
- Your car: fiesta rs turbo
- crazycage
- - Danny Boy -
- Your car: Fiesta Si 2.0
- Danny Boy - :Awesome work! Rather handy with the welder aren't you
should be , its what i do for a living
- crazycage
Nice work as usual mate looks ace
You just need to try and find enough time on your own car to get it finished now mate
Also just noticed have you made your own v band exhaust housing on your turbo mate? if so how much to do it to mine
- creator
creator :Nice work as usual mate looks ace
cheers mate, i bought the v-band exhaust housing when i i got the turbo years ago mate but i could make one , what turbo do you have?
- crazycage
- crazycage
- - Danny Boy -
small update , fitted some of the new fittings , piped in the water feed and return for both turbo and external wastegate and plumbed them into the pre rad and and also plumbed the pre rad into the main rad.
got the one way valve for the dry sump and piped that into the breather tank.
and fitted the new fuel pressure reg
- crazycage
lookin good as always gary
Looking great. What ECU you going to run as I see the coil on plug conversion?
Sent from my HTC Desire S using Tapatalk 2
- 2105adam
- Your car: Ford Fiesta 2.0 Zetec turbo
Good work. It's looking very busy in there already.
2105adam :Looking great. What ECU you going to run as I see the coil on plug conversion?
i run ms2
- crazycage
Excursion :Good work. It's looking very busy in there already.
trying to keep it as neat as i can but its not working
- crazycage
jesus this is one complicated engine bay, looks bloody brilliant though!!
them 888's have reached theyre end thou
- crazycage
looks awesome as usual gary !.. now we have the same fuel reg i could do with picking your brains ..i know you havent had it running yet but what sort of pressure would you see at idle? my injectors are 475cc at 3 bar.. would i see 3 bar at idle ?cheers
- FRSJON
that is looking awesome
surely sillicon or rubber hoses would have been cheaper?
Looking great Gary
- luca
Really looking good... cant wait to see it all painted and fibally all finshed...
- TIL13R
FRSJON :looks awesome as usual gary !.. now we have the same fuel reg i could do with picking your brains ..i know you havent had it running yet but what sort of pressure would you see at idle? my injectors are 475cc at 3 bar.. would i see 3 bar at idle ?cheers
you need to pull the vacuum pipe off the reg and block it so you dont have a air leak then start the engine and adjust the reg , 3 bar at idle is fine
- crazycage
crazycage :FRSJON :looks awesome as usual gary !.. now we have the same fuel reg i could do with picking your brains ..i know you havent had it running yet but what sort of pressure would you see at idle? my injectors are 475cc at 3 bar.. would i see 3 bar at idle ?cheers
will do ,cheers
- FRSJON
cheers gary,did fuel pressure today and was 3 bar with vac pipe on and 3.5 bar with it off so turned it down ..thanks again
- FRSJON
- crazycage
great work gary
- FRSJON
oh my! that must have a massive engine bay!
great work
great work
- crazycage
HCS PIMP :that an r32 lump ??? golf bI TURBO
no next guess please
- crazycage
