fiesta stuttering off boost?
4 posts • Page 1 of 1
my xr2i turbo is stuttering on light throttle at cruising speeds, i have changed all the sensors but the water temp sensor but choke works fine so didnt think id need to. Also holds back a touch between 3-4k rpm when you floor it but all fine when you feed it in. car is running standard ecu/injectors/boost but has a t3 turbo.
- Boostjunkie
Re: fiesta stuttering off boost?
tps maybe or the air/fuel ratio plug on the side of the many is it a rs or a 2i air/fuel sensor the rs has the square plug
and im guessing its a 2i loom u using
- mikeymikeyp
no idea where the air fuel plug is?? yes it does look like a 2i loom as theres no amal connection. ive changed tps/map sensor/act/coil pack/leads/plugs/co potentiometer all to no avail
- Boostjunkie
Coolant temp sensor could be causing it id try that theyre only cheep
- ZetecsTurbo
- Your car: Mk5 Zetec s
