FIESTA TURBO BRAKES - Now MG ZF Thoughts
Re: FIESTA TURBO BRAKES - FOCUS RS BREMBOS
Postby stevo™ on Fri Jan 23, 2009 3:50 pm
yeah mines sorned now till funds are better as iv gotta buy the rest of the brake bits and fit them along with a new battery cage for the boot a new amal valve a uprated fuel and pay the tax lol it never stops :cry:
stevo™
Postby stevo™ on Sun Jan 25, 2009 3:45 pm
theres 2 types of 406 coupe the 2.0l and a 3.0l v6 which one has the discs i need?
stevo™
Postby Ram on Sun Jan 25, 2009 4:01 pm
it was only the v6 coupe that came with brembos so i guess you want those discs?
Ram
Postby Ruishy1 on Sun Jan 25, 2009 6:36 pm
Ram :it was only the v6 coupe that came with brembos so i guess you want those discs?
correct, what price are you paying for the discs ?
i might be able to get them cheaper
Ruishy1
Postby stevo™ on Sun Jan 25, 2009 8:07 pm
well i havent seen my chum yet but on ebay there going for like 130+quid :cry: then theres the focus rs brake lines at 79+quid :cry: then the brakets 90quid plus the 125 i paid for my focus rs brembos :D cheers xrsi i thought i was gona be getting a decent cheap set up lol o well atleast it will be a good set up
stevo™
Postby Ruishy1 on Sun Jan 25, 2009 9:20 pm
should be able to get a set for 80 quid ish mate :P
whatever you do dont pay 90 quid for a set of brackets, thats a complete rip off !!
Ruishy1
Postby RSdan123 on Sun Jan 25, 2009 10:40 pm
Ruishy1 :thats a complete rip off !!
true it is but if you dont have the time and tools its the price you have to pay
RSdan123
Postby Ruishy1 on Mon Jan 26, 2009 12:30 am
for 90 quid id make the bloody time :lol:
and if you do buy brackets mate can you send me some dimensions ?
il make them up for a pittance for anyone else doing the swap :wink:
Ruishy1
Postby stevo™ on Mon Jan 26, 2009 5:44 pm
could you knock some brackets up then cheaper than 90quid?
stevo™
Postby Ruishy1 on Mon Jan 26, 2009 7:59 pm
stevo™ :could you knock some brackets up then cheaper than 90quid?
if i had the calipers, discs and front hub assembly i could knock one up for about 30 quid :lol:
To do it your self make it out of plywood of mdf first, then transfer it to a high grade steel or super dural :wink:
Ruishy1
Postby stevo™ on Tue Jan 27, 2009 12:49 pm
i have no tools to make the brakets with :(
stevo™
Postby Ruishy1 on Tue Jan 27, 2009 3:24 pm
stevo™ :i have no tools to make the brakets with :(
you dont need alot of tools mate, make them outta some wood, and any fabricater could make them up in no time for you for maybe 30-40 quid :D
Ruishy1
Postby RSdan123 on Wed Jan 28, 2009 5:32 pm
done some messuring today on a evo 8, they use the same 330mm x 28mm disc and the same brembo caliper.
know you have a lip on a used disc well from lip to lip was 25mm so i think you will get away with using the 300mm x 24mm ST170 disc :D
RSdan123
Postby Ruishy1 on Wed Jan 28, 2009 11:21 pm
RSdan123 :done some messuring today on a evo 8, they use the same 330mm x 28mm disc and the same brembo caliper.
Its not the same brembo claiper, the evo one is much larger, believe me :wink:
Ruishy1
Postby RSdan123 on Thu Jan 29, 2009 12:24 am
ah, it look the same + it used the same size disc! even still thats better news if you could get away with using 300mm disc on the bigger evo caliper then surly it will be ok on the smaller focus caliper! :rolleyes:
RSdan123
Postby Ruishy1 on Thu Jan 29, 2009 1:36 pm
RSdan123 :ah, it look the same + it used the same size disc! even still thats better news if you could get away with using 300mm disc on the bigger evo caliper then surly it will be ok on the smaller focus caliper! :rolleyes:
Its not he diameter that causes problems, its the height, centre bore and width that do.
You cant really use the ST discs on the brembo FRS caliper as they are too thin, when it gets to near end pad life, your braking will virtually dissapear, and with something as important as braking, you cannot take chances :aviator:
Ruishy1
Postby stevo™ on Thu Jan 29, 2009 3:33 pm
i think il just buy the brakets
stevo™
Postby RSdan123 on Wed Feb 18, 2009 7:30 pm
anyone every used the MG ZF Trophy calipers they are made by AP RACING and they use a 304mm x 24mm disc..... they would be ideal for using the Focus ST170 discs!
some here
http://cgi.ebay.co.uk/MG-FRONT-PAIR-OF- ... 240%3A1318
RSdan123
Re: FIESTA TURBO BRAKES - Now MG ZF Thoughts
Postby Ruishy1 on Thu Feb 19, 2009 7:28 pm
you can use any caliper mate, it all depends on the discs sizes, if the trophy use the same size discs as the ST, then use the ST discs, and the brackets will position the caliper where it needs to be, but remeber, now you need to push alot more fluid, so your master cylinder WILL need upgrading :)
Ruishy1
Postby stevo™ on Mon Mar 02, 2009 2:23 pm
ah i suppose mine will to whats a good ugrade?
stevo™
Postby Ruishy1 on Mon Mar 02, 2009 5:47 pm
im sure the escort MS and servo can be made to fit with some small mods, but i cant remeber which one it is :lol:
Ruishy1
Postby RSdan123 on Mon Mar 02, 2009 7:19 pm
i think its the mk5 rs2000, never done that conversion but seen some for sale before!
RSdan123
Postby stevo™ on Tue Mar 03, 2009 10:30 am
il have to keep an eye out then
stevo™
Previous
