fiesta turbo engine mount
Postby davis89 on Sun Nov 24, 2013 3:15 pm
as above really but im after the metal part of the mount...the bit that bolts to the block then houses the rubber mount cheers
davis89
Your car: fiesta rs turbo
Re: fiesta turbo engine mount
Postby chippy_rs on Sun Nov 24, 2013 7:58 pm
davis89 :as above really but im after the metal part of the mount...the bit that bolts to the block then houses the rubber mount cheers
Hi mate I'm sure I have a few down the unit I'm back down there on Tuesday so I will check and let you know :)
Chippy
chippy_rs
Authorised Trader
Authorised Trader
Your car: S2 RS TURBO
Postby mikeymikeyp on Fri Jan 31, 2014 11:21 am
im looking for the other bit that bolt to the car
mikeymikeyp
Postby rs220bhp on Fri Jan 31, 2014 9:48 pm
I've got both parts. The actual engine mount is new and the mount holder that bolts to the block has been powdercoated black. You both have pm's
rs220bhp
Postby mikeymikeyp on Sat Feb 01, 2014 5:56 pm
thanks for the reply mate im sorted now
mikeymikeyp
