Fiesta turbo MTX75 conversion - servo sorted!! 24/05
Postby heeman10 on Mon Mar 19, 2007 10:59 pm
Glad to hear you've had it up in the car for a proper look :) Phones can be so annoying at times!!
Postby xrsi on Tue Mar 20, 2007 12:49 am
yeah is great to se that it will actually fit properly and not bee as much of a ballache as i first thought!
well here are all the progress pics that i have skipped out over the last 2 updates
engine etc out and engine bay given a quick clean with degreaser.
Dash out
Misses got bored so decided to add comment to the white board
Then got even more bored helping and thought it would be funny to make a glove man...
Now comes all the bits i have ammassed to put on the car as it is being changed and rebuilt
Now for the test fitting of the engine and box together.
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby xrsi on Mon May 07, 2007 10:31 am
bit of an update as i aint done one in months! :(
right well my clutch idea had to go out of the window due to the idea of getting the plate splines changed not being cost effective and the idea of getting the same plate made with diff splines not going to work i have had to rethink alot of things hence the delay.
i have now gone for an aluminium billet focus flywheel which weighs next to nothing and have got a helix group N spec zetec 6 paddle clutch kit on order.
the chassis leg of the car has been cut and will need a little more work for it to completely clear the box as i wish it to but the main problem i am now facing is mounting the box in the car!
the way i wanted it to mount was using the std cradle and have custom mounts made up to fit to vibratech mounts but that is not going to work as the gearbox lowest point is over an inch lower and fouls the cradle and stops it from fitting to the car.
have also got myself a rover inlet to chop up and see if my ideas on that will work as a low cost option!
so its now full steam ahead getting it ready for ford fair, will try get some pics up later if i can get any.
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby Excursion on Mon May 07, 2007 2:22 pm
That is one big gearbox :o
Postby niracka on Mon May 07, 2007 4:36 pm
Looks like this is giving u alot of grief man. Good to see that your sticking with it thaugh. I was thinking about doing this when i get an rst but now I am having second thaughts. Anyways good luck finnishing it off for ford fair man and I hope it all goes smoothly now :)
Ollie
niracka
Your car: E46 M3
Postby J-Dee on Tue May 08, 2007 12:24 pm
What rear bumper is that? im likin it :D
J-Dee
Location: New Malden, Surrey Owns: The Imperial :) Mixes: DnB, Bassline, Hardcore, Oldskool, Breaks, Garage
Re: new pics plus mtx75 gearbox - update 10/11 new bonnet pins
Postby xrsi on Sat Nov 10, 2007 7:16 pm
Well seeing as i havent touched the car in months i thought i better look at it again.....
mate rang me up this morn and asked could i take him to pick up a bonnet that he was going to cut up, he was after a cav or escort as he wanted the metal for welding his astra GTE up and would be given a bent bonnet so had to go and pick it up ='s very cheap metal to weld with.
so after a bit of thought i managed to get him to look for a slightly bent bonet from a fiesta so i could test fit my new bonet pins that have been sitting on top of my desk for months and if it cost a few £ then i would pay for it to save hacking up my scooby vented bonnet and then realising they wouldnt fit right and ruining a very good bonnet that cost a fair few pound to have done!
These are the pins i have had for a while,
Aerocatch locakble ones so that i can completely remove all traces of the bonnet latch from my slam pannel when i make the removable item and not worry about them comming open while moving or some lowlife being able to get in my bonnet.
so set about randomly hacking at the slightly dented bonnet and these are the results, perfect for where i want them so will be getting the body shop to fit them in my bonnet so if they make the hole to big it's their fault! :lol:
what do people think over these
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Re: Fiesta turbo MTX75 conversion - update 10/11 page 2
Postby heeman10 on Sun Nov 11, 2007 11:36 am
Aero catches are definitely a far neater solution, plus have that added bonus of a bit more security - possibly even more security than the standard assembly! :lol:
Re: Fiesta turbo MTX75 conversion - update 14/11 page 2
Postby xrsi on Thu Nov 15, 2007 12:21 am
quick update.....
the rover inlet manifold has arrived and has been test fitted (only roughly) and am now finding the best priced manifold adaptor plate so that it can be bolted on and all the modifications planned so that it can be powder coated after i get the gearbox mounts done for the mtx.
Didnt get any pictures as there wasnt anything to show really, but will look million times better with the RS1600i rocker cover than the std inlet.
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby niracka on Wed Nov 28, 2007 12:12 pm
Still at it then man?????
get some pics up of your modified chassis leg ect as i'm really interested to see how your mounting the box ect. Its just soooo big it hardly seems possible lol.
Keep it up dude :)
ollie
niracka
Your car: E46 M3
Postby xrsi on Wed Nov 28, 2007 3:08 pm
yeah still at it!
Am not doing the chassis work myself am getting it done for me..... Hopefully by the legend that is scort (still trying to "make" a mate tow a trailer that far!).
Just trying to arrange getting the other bits that need doing while i am off work so that the engine can be dropped in and off to go! :D
will get pics up tho of each step of the way as and when things are done!
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby xr2ibill on Wed Nov 28, 2007 3:17 pm
Wow nice conversion looks very clean! and like the wheels they suit it! :D
xr2ibill
Postby niracka on Thu Nov 29, 2007 3:56 pm
Nice one man. Well keep us informed :)
Good luck towing her all that way hehe
ollie
niracka
Your car: E46 M3
Postby FRSJON on Thu Nov 29, 2007 10:46 pm
glad to see your sticking with it mate...love the car and love the time and effort your putting in for the box conversion... :Q :Q :Q
FRSJON
Re: Fiesta turbo MTX75 conversion - update 12/12 page 2
Postby xrsi on Tue Dec 11, 2007 6:32 pm
spent an hr this morning cutting up the bulkhead of a mk4 fiesta to get a plate that i can weld in so that i dont have to make my own mounting for the clutch cylinder on the peddle box.
This is what i came back with
To fill this hole up
Was going to have a look at welding it this evening but its too bloody cold as i dont have heating or electric in the garage so this will have to do as an update, might be able to get it done tomorrow if it warms up slightly!
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby MattPym on Tue Dec 11, 2007 6:47 pm
I think you're getting a bit ahead of yourself with the old date there :wink:
Doubt it's warming up any time soon mate :cry: Point of no return job that!
I have parts for sale!!!!.....Nice parts too!!!
http://www.fiestaturbo.com/forums/lots-of-parts-for-sale-vt185591/
MattPym
Postby xrsi on Sat Feb 09, 2008 8:30 pm
had a bit of time to have a look at the small matter of the hole in the bulkhead where the clutch cable used to come through so set about welding the part of the mk5 i got from the scrapyard mid December now the weather has got a bit warmer and the sun was shinning this afternoon.
Not my best bit of welding but for some reason i cant take to this welder i have, just cant get a lot of decent tidy welds from it.... I think it doesnt help that the wire is slightly rusty in places which is causing drag in the sleeve to the gun (have replaced the origional plastic one on it with a metal sieve and new tip
which has slightly helped but its still not right).
Anyways here are the pics of the small update....
I even managed to get a quick coat of primer from a rattle can on it to stop any rust forming on the welds! :D
Like i said above, its not my best welding ever but it should be pretty well covered anyways so not too bad, can always give it a quick skim of filler or cover them in seam sealer.
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Re: Fiesta turbo MTX75 conversion - update 9/2 page 2
Postby Ollybee on Sun Feb 10, 2008 1:38 am
Sweet! :Q
YRN Thread - yrn-vt151433/
Ollybee
Car: 1996 Ford Fiesta Quartz
Postby 285Andy on Sun Feb 10, 2008 11:40 am
loving the glove man further up! :lol: :lol:
i noticed you said the mig wire had rust on it? thats not going to help you at all matey, if it was me, id change it for a new one :)
285Andy
Your car: fiesta rs turbo
Postby xrsi on Mon Feb 11, 2008 1:22 am
managed to do a little more on it today, finished of plating the area around the clutch as the plate i got wasnt quite the correct shape around where the water pipes for the mk3 heater matrix went, as i am using a mk5 dash and heater matrix this needed covering.
As i had the welder out i decided it would be an ideal time to plate over the hole where the fiesta gear linkage goes through the floor, unfortunatly while i was peeling the carpet back after taking the seats out i found some small patches of rust on the drivers side inner arch (common problem) so cut it all right back and plated that as well.
Again not the prettiest job but its going to be covered so im not that bothered, really think that the poor welding is down to the wire and not me as penetration is great its just not doing it tidy, it seems like it wont flow right if you get what i mean!
Anyways as i am doing a quaick update i better put a couple of pics up as well!
small plate! :cry:
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Re: Fiesta turbo MTX75 conversion - update 11/2 page 2
Postby Ram on Mon Feb 11, 2008 1:31 am
top work so far :)
Ram
Postby xrsi on Mon Feb 11, 2008 1:46 am
thanks, still got a fair amount to do yet tho
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby xrsi on Tue Feb 12, 2008 6:57 pm
Only a small update today but an update none the less, this is actually starting to take shape and look like it will be a fiesta again soon.
Today i was in town going to docs etc and thought while i was there i would pop into halfords to see if the do paintable seam sealer, they do, but only in BIG tins! :(
So anyways i was relieved of £13 for the pleasure so came home and in the spare hr i had i applied a bit to the area of the bulkhead i have modified for the mk4 peddle box.
The seam sealer has made it look alot neater, am going to give it another thin coat to make it a bit more smooth tomorrow after this lot has properly cured and then can give it another thin coat of primer.
anyways here is a quick pic of before and after.
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Re: Fiesta turbo MTX75 conversion - update 12/2 page 2
Postby rs-tom on Tue Feb 12, 2008 8:22 pm
are them black team dynamics 16s . do u wanna sell em :D
rs-tom
Postby xrsi on Tue Feb 12, 2008 8:24 pm
they most certainly are, and no unless you find me some ford motorsport magnesium 16" wheels to swap! :P
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby rs-tom on Wed Feb 13, 2008 7:41 pm
rs-tom
Postby niracka on Wed Feb 13, 2008 8:05 pm
keep up the good wrk man this car needs 2 b at he fitp stand :)
ollie
niracka
Your car: E46 M3
Postby xrsi on Wed Feb 13, 2008 8:08 pm
even with the new found enthusiasm i think FITP will unfortunatly be pushing both my time and money budgets a ittle too close for comfort!
i am trying my best to arrange to make sure it will all be done but at end of the day the money is boss!
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby niracka on Wed Feb 13, 2008 8:14 pm
Yea I know what you mean man. I'v started to fear the mail as every time it arrives there is another bill or reminder which slows progress on my car :rolleyes:
ollie
niracka
Your car: E46 M3
Postby xrsi on Wed Feb 13, 2008 8:36 pm
at the moment all i am getting through is more bits of zetec engine! :D post woman hates me! :lol:
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby xrsi on Mon Feb 18, 2008 12:09 am
not best please tonight, all in all had a really crap eve!
First i will go one about everything else but the car..... I put £10 worth of derv in the daily driver, drove out of the filling station only to find that the needle didnt move, went back and asked had they had a prob as i know my gauge is 100% working got told basically to get lost so had to put another £10 in (am going to be ringing shell customer services as aint happy!) Then i ordered a load of parcels to be collected only for it to crash and have to spend another 15mins doing it again :(
But to cap it all i have done a test fit of the mtx75 gearbox with the focus black top and found that they physically wont fit into the fiesta engine bay, i have cut a chunk out of the one leg to make it a few mm wider but it still is slightly too narrow - SQAURE PEG ROUND HOLE SITUATION! :x
so not sure what to do, as it is the water pump pulley bolts that fowl the chassis leg but if i went electric pump the aux belt would prob rub on chassis leg... so having a think on that! im defo not going to give up tho as i am defo having a zetec turbo out of this engine in this fiesta! :devil:
these show how tight everything is tho! :(
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Re: Fiesta turbo MTX75 conversion - update 17/2 some bad news :(
Postby Excursion on Mon Feb 18, 2008 3:03 pm
I think you just need to step back from it and go pound some brews.
Should just require a bit of cutting and strengthening on the chassis leg?
Postby niracka on Mon Feb 18, 2008 7:25 pm
At least you know it will go in after a little work rather than getting it in place to see you need around half a foot! Just gonna have to keep your head up and keep at it mate. You will get there eventually :)
Do what Mark says and go get ratted 8)
ollie
niracka
Your car: E46 M3
Postby knuckles on Mon Feb 18, 2008 7:52 pm
xrsi :im defo not going to give up tho as i am defo having a zetec turbo out of this engine in this fiesta! :devil:
Good man :D
Dont let it get you down. You have come this far with it. You have made so much progress since i last looked. keep it up fella :Q
This may be a silly question but where will the new gear selector enter the car from now its been welded up ?
knuckles
Your car: Fiesta Rs turbo
Postby xrsi on Mon Feb 18, 2008 11:03 pm
its cable linkage so will come out at bottom of bulkhead just above exhaust tunnel!
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
