Fillin' The Bumper
Postby SYRSMAD on Sun Dec 30, 2001 11:55 am
Right you know the bit where the green stripe and the blue stripe goes on the front bumper. Yeah!? Can you fill this with just P38 filler or is there a special way of fillin it? Just don't want chunks of filler fallin out doin 100mph!!!
Sy
SYRSMAD
'Big Boy...'
'Big Boy...'
Postby KEVFRST on Sun Dec 30, 2001 12:10 pm
Plastic pladding + fiberglass filler maybe?
KEVFRST
Postby Sphinx on Sun Dec 30, 2001 1:59 pm
use fibre glass filla eg:razz:40 stuff, smooth that down and then use fibre glass sheet kit (can get it from halfords) over that. If u just sheet it ove ur left with hollow bits inside
Postby Wooly on Tue Jan 01, 2002 4:43 pm
as i work at vauxhall i asked the guys in the bodyshop what they thought of that idea recently - he said it would be bloody hard work getting it smooth etc - heat treatment would make it sink etc and would look dodgy
i will get him to smooth out the holes on the sides tho - he said he could do that no problem - i am pretty sure the 2i 16v came with this already done!!!! :smile: as i havnt seen any strips around the 16v one :smile:
Dave@dwoollands.freeserve.co.uk
drop me a mail
WOOOOOOOOOOOOOOOOOOOOLY
Wooly
Postby The Bruster on Tue Jan 01, 2002 5:10 pm
Simonz bumper filler/repair kit, costs a fortune, is like p38 to work with, doesn't crack.
The car infront is a Toyota
The Bruster
'80s Suprastar
'80s Suprastar
Postby Matt_Steves on Wed Jan 02, 2002 5:58 am
When I smoothed my XR2i rear bumper I removed the coloured insert stripe area and it is perfectly flat.
I used a pot of Loctite Plastic Padding Elastic. Absolutely brilliant stuff. Great to work with, very malleable (i.e. flexible :wink: ) and can be sanded after 15 minutes. I used 400 grit Wet 'n' Dry just after I had actually filled it (about 15 minutes) this meant it was still slightly soft and even easier to sand.
The Plastic Padding Elastic is in a big yellow tub and will set you back about £8.
No fibreglass is necessary for removing the coloured insert but for any filling you have that does Loctite do Fibreglass paste which I reckon is much, much better than that horrid P40 stuff, P38's crap aswell :grin:
Matt.
XR2 Engine
Leather Interior
AP 4-Pots
Koni/Si Suspension
Fibreglass ICE Install
http://www.fiestaturbo.com/phpBB/photogallery.php?mode=viewgallery&u=691
Matt_Steves
