first of many projects, my mk3 1.3 in mint green resto!
Re: first of many projects, my mk3 1.3 in mint green resto!
Postby jonyb4 on Sat Dec 12, 2009 1:28 am
yea thanks for the heads up on the heat, my fathers said simialr before
i know you aint trying to have a go, i could see you trying so hard not to come across as offensive bless ya :P
hopefully i can make something of this car and prove a few people wrong, but that may be too ambitious as you know a shed load more than i lol, but the paint job id doo will be 100% better than the arches i ground off it as it come lol, someone used this simialr green that werent even metallic, awful job, and the filler underneath had just bubbled
keep and eye on this mate, see how i do :)
Postby jayrs on Sat Dec 12, 2009 12:11 pm
yeah ill be watching trhis thread mate :)
Postby jonyb4 on Sat Dec 12, 2009 8:37 pm
Postby jonyb4 on Tue Dec 15, 2009 5:05 am
ok update
this is probably useless but i like the attention to detail, and since it was off, who would i be not to have painted the beam?
pics
then done the springs too
i got the arch covered in primer, to make a better contrast, making filling easier to spot the bad spots
and then in filler
also a pic of the turret covered in underseal, i will later paint this with hammerite, and then in the mint green once ive bought some of that
will start sanding it back tomorrow, then followed by some priming
Jon
Postby jayrs on Tue Dec 15, 2009 8:52 pm
good man for painting the beam.
if thats underseal on the rear turret you will find that hard to paint over mate, if its oil based that is
Postby ~nomad~ on Wed Dec 16, 2009 3:06 pm
wouldn't have bothered painting the beam myself, certainly not in a diff colour, that'll start falling off very quick and look worse than it did before imho.
~nomad~
Your car: Breadvan
Postby jonyb4 on Wed Dec 16, 2009 5:54 pm
lol yea realsied that the underseal is so hard to mix with solvents or hammerite lol
Postby jayrs on Wed Dec 16, 2009 7:20 pm
you can scrape it off and wire brush it then clean it up with thinners.
if you want to put a thickish coat of something on you could stone chip it as thats over paintable
Postby jonyb4 on Wed Dec 16, 2009 7:44 pm
i might just pop to the scrappy and get some mk4 arch covers, fat chance of finding a higher spec or maybe an si in a these yard for some mk3 ones
Postby jayrs on Wed Dec 16, 2009 7:54 pm
mk4's never came with any plastic arches.
pm jonfrs as he is breaking a Si, might have the arches still
Postby jonyb4 on Wed Dec 16, 2009 8:40 pm
i never meant plastic ones, carpets, to cover the whole turret
and cheers ill have a look for him now :)
Postby jonyb4 on Wed Dec 16, 2009 8:54 pm
:( cat seem to find him, its hard finding someone on here lol, can you send me a link to his thread or his profile? thanks
Postby MK3-MATT on Wed Dec 16, 2009 10:40 pm
I know what you mean about it being something to do, I'm currently out of work and doing stuff on the car, anything, is better than sat there doing sod all so good luck with it, all i would say is don't do too much, try and look for jobs as well as working on the car in equal measures.
MK3-MATT
Postby jayrs on Wed Dec 16, 2009 10:51 pm
jonyb4 :i never meant plastic ones, carpets, to cover the whole turret
sorry when i replied i thought ya mean arch spats i.e on the outside lol, my bad
Postby mtbdean on Wed Dec 16, 2009 11:31 pm
Ive got a pair you could buy Jon.
WWW.FIESTAGUIDES.CO.UK
The Ultimate Ford Fiesta guide source
mtbdean
Postby jayrs on Thu Dec 17, 2009 12:05 am
yeah its cool i clocked my mistake from ya other reply, took the first one wrong or read it wrong :lol:
blond moment :oops:
Postby Dave G fsi on Thu Dec 17, 2009 12:11 am
Getting there mate, keep up the good work :Q
Dave G fsi
Your car: Mk1 FRS and FRST
Postby mtbdean on Thu Dec 17, 2009 8:36 am
Hair Dryer ftw! :lol:
mtbdean
Postby jonyb4 on Thu Dec 17, 2009 9:01 pm
lol hair drier?
dean can you find out the postage please, fold them as much as you can and let me know the costs :) thanks
ha no worries jay, although some arch spats would be nice lol, could use them in the future
also i forgot to update two days ago of the current state of her
the beam is back on the car, think ive found something ont he suspension i prefere ont he mk4 lol, the top mounts for the struts, bit of a pig to get fitted properly, ended up having to remove the caps and fit them to the rubber bushes, then lift them both into the turret
anyway its back fitted now so not a worry :)
a little snag ive run into, is that one of the bolts to hold the hub on isnt going in, i think the threads bugegred on it, ive tried tapping it but nope, ill have to go to a scrappy to get some of them, i dont liek the idea of only having three studs on the hub, unless anyone knows what stud i can use to replace it with?
all for now, next i need to sand bakc the filler and give it some primer, and i think i found a small whole in the sill under the door, if so ill get it welded up
if not all the welding is done, i sorted the rust under the lower mount of the suspension and welded up the hole near the driver seat belt mount, both have been undercoated
Jon
Postby jonyb4 on Wed Dec 23, 2009 11:41 pm
all the welding has been done now, finished with the last a rust hole in the outside of the sill, its been treated and plated, will upload a pic once its been undersealed, this is the last of the rust curing
i will focus ont he paint side next
Postby jayrs on Thu Dec 24, 2009 12:04 am
well done mate, good luck with the painting :)
Postby jonyb4 on Thu Dec 24, 2009 12:14 am
lol tell me abotu it, you seen how many scratches its got? haha oh my :rolleyes:
Postby jayrs on Thu Dec 24, 2009 12:23 am
lol, it will be fine im sure mate
Postby jonyb4 on Thu Dec 24, 2009 12:29 am
:D cheers :aviator:
Previous
