fiting lower arm bushes polly or otherwise
19 posts • Page 1 of 1
lower front trailing arms are just ones that are set up for a different toe-in and camber on em, ie you can run ur car lowered, and the arms are made with that in mind, so they are still are at the correct camber
- MtY
rear small one is a right beatch, front one u just chisel out and press, or i use a vice to press em in, personally never bother just repacing the bushes, waste of time if the rear ones stuffed, only do the front one on my cars, if its customer i always stuffed a new arm on.
- snake
- Trainee Burger Flipper
- Your car: ford
yea looks and sounds (no horrid noises) like just the front onesnake :rear small one is a right beatch, front one u just chisel out and press, or i use a vice to press em in, personally never bother just repacing the bushes, waste of time if the rear ones stuffed, only do the front one on my cars, if its customer i always stuffed a new arm on.
- FezzR
- God Damn Lazy
FezzR GIRL :was the question what are the possible names for lower arms NO
then y the jolly flip! usless posts
Your original question was how easy is it to change to poly bushes, I kindly informed you I had a pair of lower front trailing arms complete with poly bushes, you asked what are lower front trailing arms, I said I didn't know, and then people started posting their ideas on what the arms actually were or what they are actually called.
Hope this answers your question.
- 16VSi
16VSi :FezzR GIRL :was the question what are the possible names for lower arms NO
i was taking the piss out of u for calling it about 4 different things
and in no way in any of ur posts have u even tried to answer the question!
- FezzR
- God Damn Lazy
FezzR GIRL :16VSi :FezzR GIRL :was the question what are the possible names for lower arms NO
I accidently called them lowering front trailing arms, instead of lower front trailing arms is my original post, how can this be 4 different things?
I was offering these arms to you to save you fitting poly bushes as they have them already fitted. I don't know how they are fitted because Leda suspension fitted them.
When I said "Hope this answers your question" I was referring to your question about how this thread had not answered your original question, and just thrown up lots of different names for these arm type things.
I take it you're not interested in them then?
- 16VSi
