Fitting a Cosworth Loom to a OFAC FRST
7 posts • Page 1 of 1
Has anyone carried this out??
Apparently the frst ofac loom just 'unplugs' but how true this is i don't know, how does it connect to the fuse box? I'm wanting to fit a cosworth wiring loom after my Zetec Turbo has been run in on its standard blue injectors. How do you know which cosworth plug goes where? Just wire colours on a wiring diagram??
Thanks for any advice
Matt
Matt
- StreetDragster
yes the FRST Loom just unplugs, there's an 8 pin multiplug behind the map sensor plate and the ECU also has an earth that runs to the battery...as to whether the Cosworth Loom will plug straight in behind it...I haven't the foggiest
oh there is also a multiplug that goes to the injector rail too...it's another 8 pin I think on the right of the inlet.
R.I.P Rob...
"The Teenage Chicks Love The Car"
- TrekkieFRST
- Location: Kings Lynn Drives: Honda Prelude Sex Appeal: 52.30% Loves: Stuff!!!
Nice one, thanks, so thats removing the fiesta loom taken care off, doesn't sound like too much of a problem, however fitting the cosworth loom still sounds like a grey area.
Can anyone offer any advice or tips on fitting a cosworth loom to a fiesta?
Do you need a particular cosworth loom?
Do you need any particular cosworth sensors?
What happens with the CPS, use the FRST one?
Someone must have done it before
Thanks for any and all advice
Matt
Matt
- StreetDragster
- TrekkieFRST
