fitting a K&N bolt on filter to a 1.1
19 posts • Page 1 of 1
i know it wont do much performance wise but only want it to make me car sound better
how much better does it sound???????
and how easy r they to fit?
adam
adam
- Adam_R
Go to car
open bonnet
undo 3 screws in top of air filter
remove clips from round sides of air box
remove lid
shut bonnet
start engine
this is how ur engine will sound! (almost)
restore airbox in revese order; or run the risk of a siezed engine by running without airbox.
open bonnet
remove lid
shut bonnet
start engine
- FezzR
- God Damn Lazy
At a risk of sounding like TJ, here we go (hold your breath)
This topic has been posted many times, use the search facility and you should find a fcuck load of walk throughs with pictures on how to do this.
There i did it, and i feel dirty
- Mr Jungle
I do, i really hate it when people say it to me! im all like "feck off" in my mind, but all smiles on the outside.
Thing is, i know in this instants there is alot of information on slapping a K&N on a 1.1 cause i did it mself when i was a Teenager. Sure didnt make it go faster, and it didnt really sound any better cause it still sounded like a pee shooter of an engine but it had to be done !!!
BB4 power
BB4 power
- Mr Jungle
- Mr Jungle
Mr Jungle :At a risk of sounding like TJ, here we go (hold your breath)
That would be splendid if searching for 'K&N' actually found any posts.
Go on try it.... No posts or topics will match your criteria...
- Liebo
arent you getting about 2-5bhp increase from fitting a free flow k&n to an engine even if it is a 1.1???surely the car will feel more responsive as well as sounding better???remember the more air the car can draw in to the carb the more air there is to combust, therefore creating more power??
- Hadyn
simon16v :but, your air filter will be sucking all hot air, so u'll be getting less oxygen, meaning u could lose power [ERRR] of that.
yes, but surely even with the standard restrictive air box on, you're sucking in hot air in anyway??with a k&n you're basically just sucking in loads more air,which obviously is better for performance. With a fuel injected car, its a good idea to make heat shields for the filter to keep engine heat away from the filter, and to run a duct from the front of the car to the filter to channel colder air.........
thats not possible on my gf bro's fester tho cuz he has a top mounted filter on a carb!!
i must say when i fitted a k&n to my old pinto powered capri, it really did make a noticable difference, around 5 extra bhp, much more responsive and a lot more noise, even with the standard zorst!!!
i presumed you'd get the same results with any carb powered car??obviously you fester boys dont think so!!
- Hadyn
Hadyn :yes, but surely even with the standard restrictive air box on, you're sucking in hot air in anyway??
well actually the entry point on the standard filter is reasonably close to the slam pannel
not just injected engines all engine will benifit from cooler intake temps!Hadyn :with a k&n you're basically just sucking in loads more air,which obviously is better for performance. With a fuel injected car, its a good idea to make heat shields for the filter to keep engine heat away from the filter,
there is many ways in which u could duct cool air to a carb arrangementHadyn :and to run a duct from the front of the car to the filter to channel colder air.........
completely depends on the original design! if the original disign has no restriction then fitting an after market will have no affect!Hadyn :i must say when i fitted a k&n to my old pinto powered capri, it really did make a noticable difference, around 5 extra bhp, much more responsive and a lot more noise, even with the standard zorst!!!
on a fester 1.0 1.1 or 1.3 when ragging u get quite warm engine temps, due to the engine being close to its limit
fitting a k&n, or any other aftermarket filter, or even drilling the original box will result in:
a suttle carb noise on full throttle or under heavy load
a debateable improved throttle response, u may get some but most of it will be in ur head IMO
you wont get any power gains that u will notice,
the difference that u notice in most cases could be achived by fitting a new standard filter,
good regular service practices are proven to be of more benifit
HTH
btw im not in anyway trying to discurage an aftermarket filter and not saying u wouldnt enjoy one just that expectations should not be that of a performance or modified engine
- FezzR
- God Damn Lazy
- RS rob
Yeah but it looks better
Still having trouble searching for a guide.
they all are similar posts ASKING how to fit...
I understand you do something with a oil breather system from an XR2i or something :S
but to be honest, i dont have a clue.
can someone who has actually properly fitted on mind posting some pics and a quick how they did it ?
then it can be made sticky and never asked for again!
thanks
/me prays for the above....
thanks
- Liebo
Yukon :I understand you do something with a oil breather system from an XR2i or something :S
u need to plug the breather pipe back into the K&N on a carb set up or get a seperate smaller K&N filter for the breather pipe, as its left dangling when you remove the original air-box...
removed the air box elbow on my gf's bro's 1.3 fester, to try and let some more air in - is this an effective simple mod or a waste of time??
- Hadyn
