fitting erst into mk3 fez sheel...
2 posts • Page 1 of 1
what sort of work is involved do you use the same mounts or do you have to weld and stuff......
- Murph
Same engine and gearbox mounts, you lose the battery tray in most cases to make space for the fuel metering head, a custom exhaust downpipe needs to be made up to make the T3 to the exhaust, and wiring loom needs to be joined to the car using a bit of DIY splicing, but it has been done before, and covered on this foum before quite comprehensively as well - try a nice Search
- Project
- fiftyoneCL
