fitting my 4 pots, help pls
3 posts • Page 1 of 1
Hi i have some recon cossie 2dw 4pot s for my fiesta rs turbo.New cos disk s and pads, a m12 tap and stainless bolts thread lock and adaptors from burton power for the brake lines.
My question is do i need to machine 4mm off the calipers as shown on the RSbible.com ? As they only show fitting these calipers to a MK4 escort rs turbo.
I s the MK3 fiesta similar ?
I just dont want to tap out my m10 holes and then not be able to use car until i can get them machined,
Please anyone that can help any info would be gratefully recieved..
CheeRS Tim
CheeRS Tim
- sparkyt
Re: fitting my 4 pots, help pls
What Disc are you useing? 283mm 2wd Disc or 278mm 4x4 disc?
I used the 283mm ones, had to put a 10mm spacers between the disc and hub and then had to get longer studs.
And had to make the calipar holes a little bigger to help line up, no machineing needed.
53 Reg Focus RS - No.2169
13 Reg Midnight Sky Fiesta Zetec-S 1.0T
M Reg 5 dr Java Blue Fiesta Track Car (In Progress)
- philip_d
- Your car: Ford Focus RS Mk1
Using 283 mm 2wd disks.
- sparkyt
