Fluids
Fluids
Postby TIL13R on Wed May 29, 2013 10:48 pm
Hello all....
Its getting close to finally filling the car up with the fluids...
I have sorted the Running in Oil and the Oil once its all bedded in..
Just have a few questions whats going to be the best fluids for the following
Escort RS Turbo LSD Gearbox.
also
Brake System.. Mondeo Servo - Braided lines - 4 pot Wilwoods
Car is going to be used on track and fast road use too...
Tiller
TIL13R
Re: Fluids
Postby RS EDDIE on Thu May 30, 2013 10:48 am
Im at the same stage.
Ive used the 20/50 mineral oil ( cheapest s**t i can find) to use for 500 miles then change filter and oil again, then the same grade for another 500, change the filter then put the real stuff in.
Gearbox oil ive chosen is a fully synthetic 75/90. (Ive got a non slipper). I phoned CTS and spoke to Bernie and he said that the semi/fully synthetic oils are good for my box. Give then a ring to confirm that its the same for the LSD box. (0141-647-5666)
As for the brake setup maybe AP Racing 5.1 would do but dont hold me to that, but im sure its good for track action!!
:D :D
RS EDDIE
Re: Fluids
Postby jayrs on Thu May 30, 2013 3:37 pm
Ep90 is the right stuff for a LSD box.
Track use you can use dot 4 or dot 5.1
The dot 5.1 has a higher boiling point so prob better suited for ya, but it absorbs water more, so regular fluid changes will be best.
Re: Fluids
Postby TIL13R on Thu May 30, 2013 3:42 pm
Thanks Jay...
Does anyone know how much the brake system holds fluid wise..!?
Tiller
TIL13R
Re: Fluids
Postby jayrs on Thu May 30, 2013 3:48 pm
Can't remember off hand, the Haynes will tell you, but say 1 litre to allow for bleeding and spare for top up
Re: Fluids
Postby TIL13R on Thu May 30, 2013 3:57 pm
Ok so 1.5 Litres should be ok :)
TIL13R
Re: Fluids
Postby jayrs on Thu May 30, 2013 4:00 pm
Yeah, unless you have a right mare bleeding the brakes and go through it all
Re: Fluids
Postby TIL13R on Thu May 30, 2013 4:14 pm
Really want to give it a good flush out...
TIL13R
Re: Fluids
Postby jayrs on Thu May 30, 2013 6:34 pm
Litre and half should be enough if you think it won't be get another litre.
You going to pressure bleed it all through?
Re: Fluids
Postby TIL13R on Thu May 30, 2013 7:12 pm
Yeah it will be pressure blead :)
TIL13R
Re: Fluids
Postby jayrs on Thu May 30, 2013 7:16 pm
Good stuff best way mate
