focus 2.0 manifold
3 posts • Page 1 of 1
focus 2.0 manifold
hi how many people have done this conversion is it hard and how much work is involved and what parts are needed
has any body got the link to the guide as it doesnt work?
- loosebmx
The 1.8 and 2.0 focus manifolds are the same all you need is manifold throttle body and cable from a 1.8/2.0 focus and some fuel line to extend to the focus fuel rail. For the conversion you also need to sort the vacum hose from the servo (i used a 1.4cfi hose and bonded the 2.0 focus inlet end over the metal fitting of the cfi hose and jubile cliped it to make a 100% secure seal) also you may need to space off the throttle cable to take up a slight bit of slack but i did not have this problem as my throttle body came with out a bracket so i made my own.
- allinking
