FORD FIESTA RS TURBO WHITE LSD Gearbox 1990 0FAB(sold)
4 posts • Page 1 of 1
Ford Fiesta RS Turbo.
Hi thanks for viewing my listing. Up for grabs is my much loved Ford Fiesta RS Turbo which has really been looked after with no expense spared. I Am looking to settle a loan so this is why the car is for sale no usual bullsh!t excuses!
It has had 7 former keepers and i am number 8, i bought the car last october and since then it has been a pleasure owning it. The car has been fully setup by Motorsport Developments in Blackpool with the paperwork, and was told it's round the 200 horse Mark. I only use Shell V-Power 99 Fuel as this was recommended. I have not put the car on a rolling road so i DO NOT know the actual power of the car although the spec of the car is colossal, It has added Civic Type R's, Corsa VXR's & Clio 182's to the menu.......
1.6 CVH EFi Turbo Engine With The T3 Turbocharger Conversion.
Ford EEC IV 0FAB ECU
+0.5mm Oversized Forged Pistons
Standard Rods With New Shells
Standard Crank With New Shells
Standard New Camshaft & Lifters
Cometic Head Gasket
Cometic T3 Turbo Exhaust Manifold Gasket
Cometic T3 Turbo Flange Gasket
Genuine Ford Inlet Manifold Gaskets
Matt Lewis Motorsport Exhaust Manifold Stud & Nut Kit
Graham Goode Racing (GGR) T3 Turbo Stud & Aero Nut Kit
Motorsport Developments Evolution 195 0FAB chip
Denso IK27 Iridium Spark Plugs
Gasflowed Throttle Body
Splitfire Twin Core 9mm HT Leads
MSD Coilpack
Beige 701 Injectors
Sierra Cosworth 4x4 Fuel Pressure Regulator
Escort Cosworth Intank Fuel Pump
Motorcraft Fuel Filter
Braided Fuel Filter To Fuel Rail Hose
Escort RS Turbo Exhaust Manifold
Escort Series 1 RS Turbo Turbocharger
Escort RS Turbo T3 Stainless Heatwrapped Downpipe
Fiesta RS Turbo 3" Stainless Exhaust System
Fiesta Rs Turbo 4" Outward Rolled Lip Backbox
Burton Power Turbo Union
Pirtek Uprated Braided Oil Feed
Escort RS Turbo Oil Return Installed
Motorsport Developments Magnetic Oil Drain Plug
Pipercross Alloy Foam Air Filter
Bailey Motorsport Oil Separator
K&N Oil Breather Filter
Airtec Stage 2 Radiator
Airtec Stage 2 Front Mount Intercooler
Samco Coolant Hoses
Roose Motorsport T3 Boost Hoses
Pro Hose Front Mount Intercooler Hoses
88oC Thermostat
Motorsport Developments Sierra Cosworth Fan Switch
Escort Gearbox With LSD
Techni-Clutch Stage 1 Organic Clutch Kit
Fiesta RS Turbo Clutch Pedal Modified To MK5 Escort Bolt Adjust
Alloy Clutch Pedal Quadrant Stronger Than Plastic Bush, Also Recommend By AP Racing For Use With Paddle Clutches
Vibra-Technics Solid Gearbox Mounts
Genuine Ford Wishbones With 2 Degree Negative Camber As Set By Ford From Factory.
New Halfords Alternator
Bosch 5 Year Warranty Silver Battery
Toyo CF1 185/55/R14 Tyres
OMP Anthracite Front & Rear Strut Braces
MK2 Mondeo Brake Servo & Master Cylinder
Wilwood Brake Bias Valve
Goodridge Stainless Steel Braided Brake Lines
Ferodo DS2500 Front Pads With New Discs
Fiesta Centre Rear Disc Conversion Kit
Sierra Cosworth (2WD) Rear Calipers & Carriers
Sierra Cosworth Mintex Rear Pads
Escort RS2000 Rear Handbrake Cable
New Steering Column Bearings
New Steering UJ
Powerflex Wishbone Polyurethane Wishbone Bushes
Powerflex Front Anti Roll Bar Polyurethane Bushes
Powerflex Rear Axle Polyurethane Bushes
Powerflex Rear Anti Roll Bar Polyurethane Bushes
Powerflex Exhaust Mount Polyurethane Bushes
Clifford 650 MK2 Alarm & Anti Hi-Jack, With Certificate Of Installation
Engine had a full rebuild @ 82k with receipts. I've probably forgot loads of other stuff with the amount that has been done. The car has a few tiny dents and has had the fuel filler cap repaired, there is a small amount of bubbling on the front drivers wing and round the rear wiper arm, It has had a sill & A Brake Pipe on for the last MOT, the bonnet has developed a crack in the middle where the charge carrier sits but can be sorted by any decent bodyshop, the car has covered 99,000 genuine miles with all the MOT's from 1993 to 2011 to prove. Also has a stupid amount of service history and receipts of everything that has been bought for it loads of genuine Ford papers, I have broken the box file it is that full so i've had to start another ring binder folder. It's that comprehensive it even has the old Tax Discs! I also do have an gen ford front panel,rear quarter and hadrian rear panel,back bumper & a minty mint frst interior that came out of a 44k car included in the sale if the price is right.
The Car Has 2 Genuine Ford Keys One With The Light In & One Normal & 2 Remote Fobs For The Clifford Alarm
I am a registered RSOC member and would like this to go to a Ford nut or a fellow RSOC member, I am 23 & looking for a bigger car now and the Fiesta is far too small for me. Insurance is 700 fully comp. for me with all modifications declared.
MOT'd Til 5th August 2012
forgot to mention its just had four new tyres,rear wheel bearings and sits on gaz coilovers.many clear hpi certificates... stack L.E.D boost gauge mounted in the drivers side air vent and gen ford mats...oil just changed & always changed every 3 months with gen ford oil and filter...oh and its fully poly bushed....front bumper could be doing with re-painting
looking for the 3k-located in the derby area de5
Cometic Head Gasket
MSD Coilpack
Beige 701 Injectors
Samco Coolant Hoses
88oC Thermostat
New Steering UJ
- davis89
- Your car: fiesta rs turbo
Re: FORD FIESTA RS TURBO WHITE LSD Gearbox 1990 0FAB
good luck with the sale mate, looks nice
- fiestarsturboblack
this i a more than well looked after car
good luck mate its a top frst
think ive still got pics
- JPXR2I:16v
I read through the advert and genuinely thought someone had copied some of my spec llama!!
Lovely car. Glwts
Lovely car. Glwts
- Maxwell
- Your car: FRST - 2wd SAFF COS
