Ford newbie!
5 posts • Page 1 of 1
Ford newbie!
Hi I am new to Fords - have got a 1990 XR2i - standard. Been searchng through old posts on here for 2 days and cant really find much tuning help!
Its a 1.6 8v... so could people point in the right direction:
1. Want to keep it fairly standard, all modding is for speed/handling
2. Dont want to swap engine
3. What is the engine code?
4. DO you think I can get second hand gas flowed heads?
5. What kind of power can I get from standard engine?
6. What mods does everyone recommend?
7. Anything likely to fall off in next few months? Common problems I should check?
Thanks for all help! Cheers
Red XR2i
Lupo GTI
Lupo GTI
- tdwindustries
This is what i have done to my ford fiesta xr2i 8v
Ashley 4-2-1 manifold
Scorpion Exhaust back box and tail pipe
K&N Induction Kit 57i
New clutch
New Pistons Ring Kit
New Rocker Arms
Nut for Rocker Arms
Kent Cam Vernier Pulley
Kent Cam Belt
Kent Cam, Cam Kit cvh32
New Rad
Silicon leads magnecor,plus ford oil filter, spark plugs, and fuel filter
Over Size Pistons Kit
Bigger Bearings
Bigger Crank
New Conrods
RECON EFI THROTTLE body
Lucas Fuel Pump
New Cylinder head 1.6.... its been skimmend twice and cleaned in acid
New head gasket kit
I done a rebuild like nearly two years ago done 16k miles onit so far
its quick but 130@bhp (108 bhp is standard on the xr2i) is like the standard FRST,
U can explore thorrtle bodies and super chip
but i think its not worth it anymore.. i only did the rebuild cuz the engine went booom. plus i get bored width the same power
hope this helps
New clutch
New Rocker Arms
Nut for Rocker Arms
Kent Cam Belt
New Rad
Bigger Bearings
Bigger Crank
New Conrods
Lucas Fuel Pump
New head gasket kit
hope this helps
- Xr_Dub
Good work, thats a lot of work. I agree about superchip, but not throttle bodies.
My problem is time and money, the great thing about this car seems to be everything is dirt cheap and lots of Ford parts are useable between models. So I am looking to do it all on the cheap/free.
There must be so much kit knocking around now second hand - including superchips just got to track it down.
Thanks for the info - 130BHP is very good figuure
Red XR2i
Lupo GTI
Lupo GTI
- tdwindustries
common problems are rust.
fuel cap
bottom of doors
arches
sills
seat supports underneath car
boot
then theres the tappets, fuel lines may need changing if there original ones because they tend to rust aswell, which i found out myself when my old car sprung a leak
gear box mounts go quite often, just buy some uprated ones and you'll be fine. cant think of anything else mate. please add to the list if i've missed anything out.............
fuel cap
bottom of doors
arches
sills
boot
- dee_RS_2ltr
By this point the simplest thing you could do to improve the power would be to rebuild it, even if too standard spec. Most of these engines are getting pretty tired and are down on power.
A rebuild would have it back like new
- Stoned
