front mounted intercooler
6 posts • Page 1 of 1
Hi,
i have got a fiesta turbo with the T3 conersion, i have got a front mounted intercooler with external fans. i was advised by Paul at engine advantages that my car will over heat during the warm weather and didnt think nothing of it, but now i've noticed the difference i need to get another fan and bolt it on to my radiator but with the space i have on my Rad the fan will only be cooling my down pipe and not the turbo!
has anyone got any ideas how i can get more cold air going onto the engine?
i have already got a induction installed.
many thanks
many thanks
- outoftheordinary
Re: front mounted intercooler
Right you will need as much of the bumper cut away as you can then 75* thermostat the biggest fan's you can get you will find the spal fan's are the thinest by far (52mm i think) and as you have a front mounted cooler you can have a longer rad (alloy is better for cooling) im going to look at getting a cossy fan switch as there ment to come in earlier
- j7aoc
where about do u get a 75* thermostat from mate
- shalon
Ebay you need to cut them down to get them to fit that's all in the ebay add it's easy i can't see them on ebay now but if you can get a 82 then that still would be good get a electric fan switch burton power sell them for a £33 there easy to fit and you can adjust the fan to come on at around 70*
- j7aoc
morrets used as air intakes bonnet riseres let hot air out the back of the bay. fan on a switch is a life saver mate im always using mine
- rs-tom
