Front Speakers, E/W & C/L
4 posts • Page 1 of 1
Hi People!!
Just so i dont appear stupid with questions - my fiestas my first car - and I'm totally new to modifying!!! lol
I've just bought some new 5.25" speakers for the front, but the connectors are different, i've got new wires, how do i get my new ones wired up??
I'm de locking the boot and putting in a boot release system, then looking at getting e/w & c/l. How hard is it to install? Can a nonce do it lol c
Drives - Combo Van for Work!! 1986 Xr2 hopefullyl!!
- lukestkd
If the speakers are the standard ford connectors you will need two spade connectors for each speaker to adapt the new wires.
C/L + E/L is relatively easy to do but involves a lot of titting about and you have to split the fusebox to solder in some new wires. There is a comprehensive guide in the guides section which explains it all.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
ollybee :C/L + E/L is relatively easy to do but involves a lot of titting about and you have to split the fusebox to solder in some new wires. There is a comprehensive guide in the guides section which explains it all.
and on http://www.fiestaguides.co.uk
3 and 5 door versions mk3 and mk3.5 versions as wel
- AW3K
AW3K :ollybee :C/L + E/L is relatively easy to do but involves a lot of titting about and you have to split the fusebox to solder in some new wires. There is a comprehensive guide in the guides section which explains it all.
The one's I used! All you need.
- Ollybee
