Frst 200bhp club or close as.....
8 posts • Page 1 of 1
Well as i am totally new to all this (well talking for my friend) what is needed to achive a nice 200bhp or around that.........
Could you post up your specs please and power output.
would i need these items?
T3
Double Capaticy intercooler
Car has got Alot of headwork done ie P+P Big Valves, Solid Lifters, Kent Cam.
Would uprated fuel pump be any good? if so what one and how much?
What sort of injectors should it be running too?
Also any other things that i should consider?
Engine is currently cvh, not looking to go full Zetec but would possibly cinsider ZVH
Tiller
T3
Tiller
- TIL13R
Re: Frst 200bhp club or close as.....
My brothers made 211bhp on my mates Dyno Dynamics rollers spec was.
Stage 1 Hybrid T3
Beiges
195 chip
Kent CVH 35 cam and vernier
Cossie fuel pump
Pace intercooler (small item)
Some carefull setting up on the rollers with a peak of 21psi and holding 19psi.
Wait for the new spec. I've seen what's on order
Stage 1 Hybrid T3
Beiges
195 chip
Cossie fuel pump
im putting mine on the rollers tommorow so ill let ya know how i get on
- mk3modda
use a cossie fuel pump, beige injectors and use either a front mount or uprated intercooler with a T3 (has been done with a T2) and a remap should see the magic 200
- SiZT
SiZT :use a cossie fuel pump, beige injectors and use either a front mount or uprated intercooler with a T3 (has been done with a T2) and a remap should see the magic 200
Is that without changing the internals or dropping the compression?
Thanks,
Neil
Right then... What can I break next? ???
- NeilH
Yes. my brothers made his 211bhp on a factory bottom end that had never been apart and 111k miles under its belt. Who says Fords are shonky?
my mates saw 217bhp on his 120k cvh turbo engine, never missed a beat, ran it at that spec for around 2-3 years, finally deciced to get a focus rs and the fiesta was scrapped due to the amount of rot in the shell, engine still lives on, regular oil changes do the engine wonders!
- garyhurn77
I have 225BHP and I used T3, 2,5" exhaust system with 1 box, ported head, big IC, Walbro 255 H/P fuel pomp, 701 injectors, PiperCams 285T2, and live map. I have 18psi of boost.
ZetecTurbo
- PUMARST
