FRST ENGINE TRANSPLANT
5 posts • Page 1 of 1
I want a fezzie turbo but i used to have an si (hence my name) thing is though a mate of mine is selling his fiesta, its m reg so its the mk 3.5 which i prefer. his engine is only a 1.3 can rememver wot type but its a carb. basially is it any different puttin a turbo lump in a mk 3.5 rather then a mk 3?? im gonna respray my motor so it wud b best to do it with the engine out 2?
also wots everything ill need apart from the engine, loom, ecu, gearbox.
any help appricated
any help appricated
- Mikee_RS
Car: 1995 Ford Fiesta
No, exactly the same - swap looms, swap engine in, plumb in, away you go.
It's CFi, not carb, so you already have the right tank but probably wrong pump - easiest is to get the pump and sender unit from an FRST or RS1800i.
- Project
- fiftyoneCL
- Mikee_RS
- Project
- fiftyoneCL
- Mikee_RS
