frst injectors
7 posts • Page 1 of 1
frst injectors
whats the max for the std frst injectors out put that it can handle.some said a while ago it might be 160 or 170 bhp. and that the nxt upgrade was beige 701.but i thought that the beiges were rated from 195 with the chip?isnt there nothing in between?
- MK4 Rick
- Your car: Mk5 Fiesta
Re: frst injectors
iirc standard FRST Blues will flow for a max of 165bhp and the next step up Beige injectors are good for up to 230bhp butthey are pretty maxed out at this point
Re: frst injectors
as said above, 165 - 170, upto 180 if you want to take the piss (and the risk) best just upgrading for some 701's, find a crashed Punto Turbo and steal the injectors out of them, or use Lancia Integrale Turbo injectors
- SiZT
Re: frst injectors
i already have some beiges injectors,just want to no if i can stick the injectors in from around 165 bhp with out the 195 chip just to run it
- MK4 Rick
Re: frst injectors
turbonetic :i already have some beiges injectors,just want to no if i can stick the injectors in from around 165 bhp with out the 195 chip just to run it
It will run very rich without the chip. All that extra fuel going in on the standard map which the ecu is programmed to use.
- knuckles
- Your car: Fiesta Rs turbo
Re: frst injectors
i personally wouldnt use 701s they tend to over fuel when on part throttle and under fuel top end when you need least need it, id get rid and go for some management or the ian @ fiesta frenzy does a chip and injectors and map sensor
- crazycage
Re: frst injectors
crazycage :i personally wouldnt use 701s they tend to over fuel when on part throttle and under fuel top end when you need least need it, id get rid and go for some management or the ian @ fiesta frenzy does a chip and injectors and map sensor
Fuelling depends on more than an injector part number; namely the flow rate of the injector, fuel pressure and the engine management system.
