FRST juddering
14 posts • Page 1 of 1
FRST juddering
Sometimes when I floor it, the car starts to juddy, like it's being staved of fuel or something. This only happens sometimes.
Would it be dirty injectors? if so, anyone recommend any good stuff that will clean em.
- Escort Cos
time to renew the sparkies.. i guess..
had the same problem before..
could be a lack of fuel though.. (change the fuel filter.. or turn up the fuel pressure a bit..)
If you're not running standard boost.. but you are running standard ECU (not chipped) either turn down the boost.. or get it chipped..
It could also be the overboost-safety
- Jur
The engine is completly standard, standard boost, standard ECU.
If it was spark plugs, would it not do it all the time?
- Escort Cos
it didn't with my car.. changed the sparks.. problem fixed at my car..
worth a try ..
cost me around 8 quid (12 euro) to get 4 original motorcraft sparks..
they had to order them .. cause the motorcraftsparks of the FRST are ONLY made for the FRST.. and there were only 33 sold in holland..
worth a try ..
- Jur
Jur :it didn't with my car.. changed the sparks.. problem fixed at my car..
worth a try ..
33 sold in holland bit hard done by then.
Will try the plugs, will replace leads at the same time.
- Escort Cos
mine isn't an original dutch RS-turbo.. it was an 1.8i S but i converted it.. (using a english FRST donor car)
Most of the FRST sold in holland though are red.. )-: i guess 75% ..
- Jur
Jur :mine isn't an original dutch RS-turbo.. it was an 1.8i S but i converted it.. (using a english FRST donor car)
They didn't actually call them RS either, did they?
- Escort Cos
Just been out in the car again and this ain't a spark plug prob. I just tried to floor it off a roundabout the car was just jerking and stuggling to go anyway then all of a sudden it just took off.
It's like there is a blockage somewhere?
- Escort Cos
you better stop driving the car hard and get this problem looked at by a tuner before you could cause serious damage to the engine.
Is there a chip pluged in the ecu, and have u got a bleed valve on the car as it sounds like its over boosting.
- GavStyli
- Your car: Fiesta Turbo
Got no bleed valves or a chip. I tanked a load of injector cleaner in the tank and it seems to have stopped it for now.
- Escort Cos
Started again. It seems to happen when I really drive the car hard.
When I hook my boost gauge up, what reading should I be getting for standard boost?
I think I'm going to book it in at Owen Developments to find out whats wrong with it and maybe get a chip fitted too.
- Escort Cos
