Frst Mahle Pistons
19 posts • Page 1 of 1
Frst Mahle Pistons
is frst mahle piston, work and fit good on a 1.6L Zetec?
or i'm talking s**t, becouse if they work i can buy them pistons?
please help me!
becouse my friend want to turbo his 1.6L Zetec, not for that big power, but a nice sound of a dumpvalve, and a little good power.
is it the same bore?
can u help?
please help me!
can u help?
- g-flash
visit http://www.vanaaken.com/ they do a bolt-on Turbo Kit for the 1.6 Zetec engine.
- chumkila
- Dirty Post Whore!
Thats doesnt change the engine does it?
That dont change the fact that if u want questions answered their there.
Van Aaken's kit bolts straight-on and no mods are required as it runs low boost.
- chumkila
- Dirty Post Whore!
- chumkila
- Dirty Post Whore!
- chumkila
- Dirty Post Whore!
FRST bore 80.0mm
1.6 Zetec 76.0mm
You can't slap on a set of CVH pistons and hope it will work you have other things to think about like the size of the little end are thay the same and the hight of the piston [ERRR] if you fit them thay might protrude out of the block.
It would be easyer if you just get some low comp pistons
1.6 Zetec 76.0mm
- Andy'sFRST
yes i think it's more easy slaping a low compresion piston, but the is that my friend don't want to spend so much money on this 1.6 Zetec becouse it's piontless, so can he get the pistons to machined them and low the compretion by the same pistons of the zetec?
if yes what's the compresion ratio, should it be to run at least 10psi boost.
thanks for your help guys, you're the best.
- g-flash
- chumkila
- Dirty Post Whore!
yes NikFRST, that's what his gonna do, a decompression plate is the best i think for not spending big money, but he don't know what should be the thickness of this decompression plate.
and with this decompression plate, what's the safest boost limit to run on?
- g-flash
g-flash if u spent less time goin round in circles on here and paid attention to wot some ppl wrote you'd have your answer by now.
So DID YOU email the webmasters of those sites asking this question? I think not.
- chumkila
- Dirty Post Whore!
g-flash, I just read the other post asking about decompression plates, etc. Also, I didn't realise until I re-read this post that you was asking about a 1.6l. Some other ppl have already mentioned going for the 1.8 or 2litre Zetec. Then you would have much bigger power to start with. If your friend goes ahead and turbocharges his 1.6 with a decompression plate he will be lucky to acheive 140bhp without melting a piston. If he goes for the 2litre he won't have much less bhp as standard then if he turbocharges that then he can get silly power.
- NikFRST
