Frst = no spark =(
Frst = no spark =(
Postby BOBFRST on Tue Mar 18, 2014 10:00 pm
Alright peeps got a problem with the lady & it appears she wont spark, took a plug out & cranked her & nothing so I tested the plug connected to the coil pack & it seems to be getting 12 volts, on the 3 pins the top read 9.4-9.8v, middle 12v, lower 9.4-9.8v so I changed coil pack & this is where my dilemma is. The original coil pack had a code of A2A where the spares I have are AA & A1A is the pack on the turbo a model specific item? ie higher output so the spares dont supply enough voltage? & are they known to fail? At a bit of a loss as what else could cause no spark? Crank sensor maybe? Please Heeeeeeeeeelp :lol:
CheeRS
BOBFRST
BOBFRST
Your car: 1991 Fiesta RS Turbo
Re: Frst = no spark =(
Postby Gmc on Tue Mar 18, 2014 10:05 pm
sounds daft, but unplug the EDIS module, spray the contacts with some WD40, and reconnect it. Had an issue with mine when it wouldn't start and it turned out to be a little bit of corrosion on one of the contacts, it may well be something as ridiculously simple as that, so give it a go just incase ;)
Scottish? :Join The West of Scotland RSOC
Website : http://www.westofscotlandrsoc.net
Gmc
Postby BOBFRST on Tue Mar 18, 2014 10:46 pm
Thanks for the tip mate I'll give it a try :)
CheeRS
BOBFRST
BOBFRST
Postby mikeymikeyp on Tue Mar 18, 2014 11:56 pm
coil pack will work if its the same and the crank sensor would be my next port of call , iv a spare if u want a shot of it
mikeymikeyp
Postby BOBFRST on Wed Mar 19, 2014 12:21 am
Thats the thing chum im not sure if its model specific cos the others I tried are outwardly identical but slightly different part numbers :-? The crank sensor had been a thought & if you've a spare going id gladly take ownership of it :lol:
CheeRS
Rob
BOBFRST
Postby Boostjunky on Wed Mar 19, 2014 9:08 am
Should be the same and work no matter if the part no is slightly different
Crank sensor is fubarrd by sounds of it ,sure you can check the resistance value to confirm its dead
Boostjunky
Your car: Ford
Postby mikeymikeyp on Thu Mar 20, 2014 12:31 pm
pics to follow,,,,,,,, its a cvh block you have aint it Bob
mikeymikeyp
Postby BOBFRST on Thu Mar 20, 2014 5:20 pm
Yep still sticking with the trusty cvh matey lol that could be the problem ive replaced both the cps sensor & wiring before because of heat damage, the wirings been well protected with heat resistant coating & reflective tape & ive fabricated heatshields but the damage could have been done already. Thanks for the pics & whats the damage? :D
CheeRS
BOBFRST
BOBFRST
Postby BOBFRST on Thu Mar 20, 2014 5:22 pm
Boosty have you any idea of what the resistance value should be matey? Ive got a multi meter but just wondering if you know off hand :D
CheeRS
BOBFRST
BOBFRST
Postby fezzRS on Sat Mar 22, 2014 8:21 am
Is tge fuel pump priming
Your car: run about
Postby BOBFRST on Sun Mar 23, 2014 12:29 am
Is indeed Fezz though I pulled the fuse while I was checking for spark, don't want a load of fuel in there while I was doing it, but if it doesn't play ball soon it'll be getting a tenners worth of super unleaded & a match free of charge :lol:
CheeRS
BOBFRST
BOBFRST
Postby mikeymikeyp on Sun Mar 23, 2014 10:43 pm
dont DO that
mikeymikeyp
Postby AR-FRST on Fri Apr 18, 2014 7:41 pm
Where is the EDIS located?
Any photos?
AR-FRST
Your car: Fiesta RST
Postby mikeymikeyp on Fri Apr 18, 2014 8:17 pm
its on the bulkhead next to the map sensor
mikeymikeyp
Postby AR-FRST on Fri Apr 18, 2014 8:36 pm
mikeymikeyp :its on the bulkhead next to the map sensor
Thank you.
WD didn't do the trick.
AR-FRST
Postby jayrs on Fri Apr 18, 2014 8:51 pm
If it's chipped talent out and try it
I would say check the cps plug and make sure you haven't got a break in the wires from the cps to the edis, check continuity with a multi meter
Also check the fuses and clean the pins in the green relay just to rule it out
Postby AR-FRST on Sat Apr 19, 2014 10:42 am
jayrs :If it's chipped talent out and try it
Can I just remove the chip.. or does the ECU need to reset or anything like that? Just asking..
How do I check the CPS's continuity?
Thanks for the help.
AR-FRST
Postby jayrs on Sat Apr 19, 2014 12:15 pm
Ignition off pull chip out, same
For refitting, disconnect battery for safety just in case
Basically pop the plug off the CPS and the plug off the edis and check the cable from one end to the other to see if there's a break.
Off the too of my head I think the wire colours are green and blue and green and yellow, but check the Haynes manual as I could be wrong as it's been a while since I check any cps
Postby AR-FRST on Sat Apr 19, 2014 12:51 pm
jayrs :Ignition off pull chip out, same
Thanks you're a star
AR-FRST
Postby AR-FRST on Sat Apr 19, 2014 1:29 pm
See photo.
I have stripped alot of the black electrical tape off, but as of yet i am unable to find the the other end of the yellow/green cable.
AR-FRST
Postby AR-FRST on Sat Apr 19, 2014 1:31 pm
Please see photo
AR-FRST
Postby jayrs on Sat Apr 19, 2014 2:53 pm
The cps if is where the wires run to mate.
As I said fella I could be wrong with the wire colours so check the Haynes to be sure
Postby AR-FRST on Sun Apr 20, 2014 4:23 pm
I'm just going to replace the CPS.. It's probably never been changed.
AR-FRST
Postby Boostjunky on Mon Apr 21, 2014 9:54 pm
BOBFRST :Boosty have you any idea of what the resistance value should be matey? Ive got a multi meter but just wondering if you know off hand :D
CheeRS
BOBFRST
From memory
to test if the ckp is working ok follow these steps
ingnition off
disconect the cps sensor
check resistence on the cps terminals
should be 200-450 ohms
Also worth continuity testing the cps wires back to the ecu plug as they go brittle and suffer with breaks
Boostjunky
Your car: Ford
Sorry for the delay didn't see your reply mate
Hopefully you have it sorted now
Boostjunky
Your car: Ford
Postby georgiocat on Wed Apr 23, 2014 7:56 am
Did you manage to solve your problem? If not, a simple schematic of the EDIS is here:
http://www.fiestaturbo.com/forums/guide-edis4-schematic-vt178886/
Also I am sure that I have somewhere a way of testing the cps connected and powered, I will have a look and post it.You don't need to remove it.Ofcourse if you want to remove it to check it if it is broken,dirty etc etc then ok.
My Ford Escort ride
georgiocat
Postby BOBFRST on Wed Apr 23, 2014 11:20 pm
Thanks for all the help guys still no joy but working my way through your options so keep you posted, aint gave up hope yet :D
CheeRS
BOBFRST
BOBFRST
Postby georgiocat on Thu Apr 24, 2014 5:03 pm
Good luck. I gave a guick search regarding CPS way of testing but had no luck... I have a lot of notes in some oily notebooks,I will continue searching... I'll inform you when I find anything...
My Ford Escort ride
georgiocat
Postby mikeymikeyp on Thu Apr 24, 2014 7:14 pm
BOBFRST :Thanks for all the help guys still no joy but working my way through your options so keep you posted, aint gave up hope yet :D
CheeRS
BOBFRST
So I guess you aint got your motor running yet
Whats happning with it
mikeymikeyp
Postby BOBFRST on Thu Apr 24, 2014 9:32 pm
The b1tch is fighting us every step :lol: but I'll get there I aint that easy defeated :D
CheeRS
BOBFRST
BOBFRST
