FRST: Oversized pistons&rings - pros and cons??
12 posts • Page 1 of 1
Need some advice really, so any much appreciated.
If you bore the cylinders out to 0.5 oversize, am i right in saying you have buy larger pistons aswell as rings? or can you just use larger rings to take up the slack??
The whole process will cost in the region of £600 is it worth it?? does it gain a large enough lower compression to make it worth while??
Or will the standard pistons and bores be could enough for a reliable 200bhp+
dan
dan
- project_mistral
the only reason they give the option of 0.5 1.0 and 1.5mm overbore is in the event that the cylinder is worn when you come to rebuild it, and the pistion is slack in the cylinder,
thus you over bore by 0.5mm, this takes the cylinder back to a round shape, (wear makes it oval)
there is no performance gain at all (well any there may, is not worth thinking about otherwise you`ll just be disappointed)
- FezzR
- God Damn Lazy
thanks for that.
the bores in that case seem to be ok on mine. The lip at the top of the bore is minimal, i was able to push the piston out by hand instead of having to use a hammer like i was told! not bad for a79k engine.
- project_mistral
louma84 :it will lower the compression ratio slightly, but i don't no by how much
it wont lower, it will raise the comp ratio
RS1600i restore, weld in multipoint cage, t34 zetec turbo
http://www.passionford.com/forum/viewtopic.php?t=130905
- Red16
Red16 :louma84 :it will lower the compression ratio slightly, but i don't no by how much
indeed as the man says, larger bdc capacity into the same tdc volume,
as long as all other things are equal etc
- FezzR
- God Damn Lazy
increasing the capacity isnt the key fact because it can be done in so many ways
as i said before , its about the capacity with the piston at TDC and BDC
wider pistons mean more BDC capacity but the same TDC capacity
decomp plate/ pistons means BDC bigger capacity but with a bigger TDC capacity too
- FezzR
- God Damn Lazy
louma84 :but you would b increasing cc in each cylinder though so wouldn't that lower it? [ERRR] if ya want to lower the c/r in [ERRR] car u can skim the tops of the pistons or use a decomp plate????????
no it wouldnt, but by skimming the pistons you make the swept volume of the cylinder bigger as well as the combustion chamber volume, which is why the c/r will be lower.
if you bore the block and use larger pistons, the swept volume will be larger but the combustion chamber volume will be the same, therefore increasing the c/r.
- Red16
looks like FezzR beat me to it
- Red16
fezzR, i wouldve made a cuppa but was at me mates flat while posting, and young lads flats are crap, never anything in the bloody cupboards so no coffee got made
heres how you work out compression ratio, get ya thinking caps on
swept volume = (Bore x Bore x 0.785 x Stroke) / 1000
(Swept volume + combustion chamber volume) / combustion chamber volume = compression ratio
but all this is disregarding the volume the head gasket creates
- Red16
