Frst timing adjustment
Postby Mikeoro on Sat May 18, 2013 10:05 pm
Hi can anyone help plz how do u u adjustt the timing on a mk3rst fiesta mines high low reving on tick over and staying high revs on gear change plz sum1 gis a clue :D
Mikeoro
Your car: Ford fiesta rs turbo
Re: Frst timing adjustment
Postby FRSJON on Sat May 18, 2013 10:07 pm
sounds more like a air leak or a throttle position sensor that needs changing :)
FRSJON
Postby Mikeoro on Sun May 19, 2013 7:27 pm
Thanks ile av a gander :D
Mikeoro
Postby jayrs on Thu May 23, 2013 10:21 pm
As jon says, could also be down to a bad TPS
Clean the iscv out too
As for the timing, unless you ft a adjustable pulley on it you set the timing up to the marks on the head and the mark on the bottom cover, after that the ECU will advance or retard the timing as needed
Postby Mikeoro on Sat Jul 27, 2013 8:30 pm
thanks for your help :)
Mikeoro
Postby FRSJON on Sat Jul 27, 2013 8:35 pm
Mikeoro :thanks for your help :)
sorted ?
FRSJON
