FRST Tuning question?
9 posts • Page 1 of 1
My FRST has been previously set up at power engineering at 15psi. The car runs 2.5% co. Mileage is getting up now 70k. Ive turned the boost down to 12psi, is this ok. Is ignition tinibg set for 15psi?
K&N filter
Mongoose xzorst
165 chip
piper cam
pace intercooler
CheeRS
K&N filter
Mongoose xzorst
165 chip
piper cam
pace intercooler
CheeRS
- festaturbo
On 2002-03-22 14:28, DuncanFRST wrote:
Surely the chip is already mapped for the lower boost? In which case everything should be fine?
No....as the fuelling will be set for 15psi...if you lower the boost you will have too much fuel going in and this can cause bore wash.
Get your car checked out and make sure
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
I just thought that the MAP sensor would detect the lower boost, tell the ECU which would lower the fueling accordingly. This not correct, no?
- DuncanFRST
Erm.....kind of, but the problem is that the fuel pressure will still be set for higher than needed at full boost...which will then put too much fuel through.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
Bore wash : is having too much fuel in the cylinder that will not 100% burn, this will leave fuel in the cylinder and going out of the exhaust valves. This will eventualy cause wear on the cylinder walls and valve stems.
I dont know how too much fuel would affect the stem seals...that could be another problem.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
