frst/xr2 fuel sender/ pump unit.
Postby rs-tom on Tue Apr 18, 2017 5:47 pm
i need the whole bit that sits in the tank . the little black box on fuel sender is not letting power through so pumps not priming :(
07834376037
rs-tom
Re: frst/xr2 fuel sender/ pump unit.
Postby Joris on Wed Apr 19, 2017 2:00 pm
You can buy the little black box seperatly, just google the number on it,
it's just some surpressor with a few caps/inductor in it so you don't get the pump noise feedback in your electrical system.
(will probably run without it, but you can pick them up cheapish.)
Joris
Postby Joris on Wed Apr 19, 2017 2:01 pm
btw, don't try to measure it with a normal multimeter, won't work, just apply 12v battery on the sender unit and check if pump runs.
Joris
Postby rs-tom on Thu Apr 20, 2017 7:44 am
thanks guys . pump does run theres power into the black box but nothing out
rs-tom
