Fuel pump fuse keeps blowing!
Postby Brianscotty on Mon Jul 08, 2013 10:47 pm
HELP....???
I am hoping someone can point me in the right direction on how to get rid of this new problem..
The car has been off the road for a long time (almost 14 years). After building a new engine then fitting it I have noticed that when I start the car it runs for around 10 - 20 seconds then stops running. When I then swith the ignition back on to try & start the car again I cant hear the fuel pump priming. When I check the fuse I notice it has blown so I then replace that fuse for a new one. I then start the car again & after 10 - 20 seconds the car cuts out. Yet again its the fuse.
Has anyone on here had a similar fault? I have checked various connections & cables but I am unable to find any fault. I have ordered a new relay as the according to the existing relay it just seems to be a standard 4 pin relay so Ive ordered a replcement. I am also thinking that there could be something wrong with the ECU as according to the cars history folder the car has a few receipts from garages reporting that the previous owners had problems with the engine keeps cutting out. There is however no mention of any fuses being replaced by the garages.
I have bypassed the inertia switch incase there might be a problem with it but the car does exactly the same thing over & over again.
Any help on this would be appreciated....
Brianscotty
Your car: Vectra VXR & FRST
Re: Fuel pump fuse keeps blowing!
Postby mikeymikeyp on Tue Jul 09, 2013 9:33 am
try the connectors in the fuse box then the wires behind might be melted pins and is it the correct size fuse and have u tried running it with a bigger fuse
mikeymikeyp
Postby Brianscotty on Tue Jul 09, 2013 3:56 pm
Yep, I've checked the connections in the fuse box & the wires at the back of it. All of them seem absolutely fine. Ain't tried a larger amp fuse.
Brianscotty
