Fuel pump keep's priming
9 posts • Page 1 of 1
It happends when the key is clicked forward one when left like that every so often the pump prime's and it's run's like a dog the engine has just gone back in when you put your foot down car's ok untill you take your foot off then cut's out i've taken out the chip and try new pump relay no joy
- j7aoc
I've found out that bad earth poinst on the car gives a really weird faults everywhere. Fuel pump priming was one of them.
Also, when I had the ecu incorrectly plugged in, everything seemed faulty but the ecu
- BUTRE
Would it be an earth even if the car not running as it is doing it with one turn of the keyBUTRE :I've found out that bad earth poinst on the car gives a really weird faults everywhere. Fuel pump priming was one of them.
- j7aoc
Check the nevative pole on the battery.
When working on the car for so long, ppl tend to have the negative pole loss so that they can plug it and unplug it by hand without any tool. This will loss even more the plug giving bad earth to the car.
I experience even the central locking going nuts!!!
Check it mate and see if your problem is sorted.
- BUTRE
- j7aoc
- j7aoc
- Priezti
Didn't see that would of sayed me loads of messing around must check all post "DOH"Priezti :http://www.fiestaturbo.com/forums/post1406256/#1406256
- j7aoc
