fuel pump relay help
Postby xjtaggedx on Fri Oct 17, 2014 11:17 pm
my car randomly wouldnt start today after i had popped in to the shop. felt like my car was not getting fuel, so turned over but no spark. was told probably the fuel pump relay.
i am having a issue finding a fuel pump relay to buy. can you guys link me to where someone sells them or do you know if another car fit etc, very grateful thank you.
fiesta rs turbo h reg 1991
thank you guys.
xjtaggedx
Re: fuel pump relay help
Postby xjtaggedx on Sun Oct 19, 2014 12:47 am
Any advice please?
xjtaggedx
Postby georgiocat on Mon Oct 20, 2014 9:49 am
If you have no spark, then the trouble is not the fuel pump relay. Fuel pump relay is powered by the ECU when you crank the engine. If you can't see spark too, then I don't think that the problem is the fuel pump relay... Have you checked the fuses? If everything is fine, check the CPS, plug and it's wirring for start.
My Ford Escort ride
georgiocat
