fuel pump
7 posts • Page 1 of 1
fuel pump
what sort of a job is it to change my fuel pump????
do i need to drop the tank ect????
i have my tools at home for the weekend as i am changing the head and cam so i thought i may as well do this as well!!
any info appreciated.
- FIESTArsTURBO
hi m8, yeah you do have to drop the tank, fords put a hole in the body work under the back seat, but not big enough to get the pump through, when the tanks out tap the fuel pump around with a screwdriver to release it from the tank.
- MikeyXR2i
easy enough job to do!
me and a mate did this, this afternoon, in about 30mins!!
not really worth changign the pump tho if ur staying with std injectors as the pump wont push more throught the injectors as they can flow! (flowrate of injectors)
if u r uprating the pump get an escort cosworth one and then put the bosch 701 (beige) injectors on!!
how ever to run the injectors you also need a suitable chip (195 superchip for example) with the map to run these injectors!
but yeah, to change the tank all you do is undo the small fuel hose, put a jack under the tank, undo all 4 bolts and drop the tank, then all you do is knock the securing ring of the pump round with a hammer and screwdriver to release the origional pump, then assemble the uprated pump into the assembully of your pump and repete the above but in reverse! (dont forget to depressureise the system first tho )
hope this helps
James
hope this helps
James
- xrsi
- XR(ustyAtTheMo)SI
- FIESTArsTURBO
piece of pi$$ then fella!!!
just remember to depressureise the system first!!
hpe it all goes well!
James
James
- xrsi
- XR(ustyAtTheMo)SI
got it from matt (ml development) last week for £100 pounds!
not sure how much they usually are but did buy loads of stuff of him then tho!
give him a shout, he'll sort ya out with one
- xrsi
- XR(ustyAtTheMo)SI
