Fuel Rail Squeak?
Fuel Rail Squeak?
Postby Tweek on Tue Aug 20, 2013 6:31 pm
The first time, every time, I prime the fuel pump a random squeak sound comes from the rail and I've no idea what it is! Uploaded a video if anyone can help. The rest of the noise is some kids riding up and down the street on Kett-Kart things.
Your car: VW Golf GTD
Re: Fuel Rail Squeak?
Postby - Danny Boy - on Tue Aug 20, 2013 8:01 pm
Sounds like some air escaping or something similar to that.
- Danny Boy -
Your car: Fiesta Si 2.0
Postby georgiocat on Tue Aug 20, 2013 9:59 pm
I have the same sound.Two questions...have you replaced your fuel pressure regulator?And two...have you ever replaced the membrane in the fuel pump housing?Well to be precise,I am not sure if there is one in the Fiesta,in my Escort there is one...
It is the round thingy in the fuel feed line,just arfter the fuel pump.It has a membrane inside which compensates the pulses from the pump.Trouble is that if you have it for ages,the membrane is split,and does absolutely nothing to compensate the pulses of the pump.The fuel pressure reg has a metalic diaphragm,which under circumstances it can synchronize with the pulses and make noise.This is happening to my car...no one could find why it make this noise...
My Ford Escort ride
georgiocat
Postby Tweek on Tue Aug 20, 2013 10:21 pm
Ah right. My fuel pump doesn't have that extra bit and I've not changed the FPR, not to say it isn't that though. Might swap the rail out and see :)
Postby FRSJON on Tue Aug 20, 2013 11:01 pm
ive had this ! for the life of me i cant remember what i did if anything to cure it . didnt change anything though. its either the fuel feed needs tightening or something simple...
FRSJON
Postby mikeymikeyp on Wed Aug 21, 2013 9:33 am
put a bit of plumers tape on the thread when u fit it back on
mikeymikeyp
Postby georgiocat on Wed Aug 21, 2013 11:26 am
It's doing your head in,doesn't it?If you haven't replaced anything,check the bolts of the rails,as already suggested...mine doesn't do it with the factory fpr,so I thought to ask.It still does it sometimes too...
My Ford Escort ride
georgiocat
Postby fezzRS on Wed Aug 21, 2013 11:28 pm
undone of the fuel lines run put it in a bottle and turn the ignition over and then engine until fuel comes out should help
Your car: run about
Postby georgiocat on Mon Aug 26, 2013 9:22 am
Just a question... :) You are suggesting this,so it can take out all the air from the system...?
My Ford Escort ride
georgiocat
