Fuelling and pinking.
Postby Sparky on Mon Nov 25, 2002 5:28 pm
Is there any way that I can increase the level of fueling slightly without getting a rolling road tune?
My car pinks slightly when the boost builds and it is making me cringe!
I'm really strapped for cash as well at the moment and won't be able to get a RR til after christmas.
Any Ideas? Can the fueling be increased by adjusting something or is it all strictly controlled by the ECU?
Thanks guys :)
Sparky
Postby snake on Mon Nov 25, 2002 6:20 pm
only way to increase fueling on fixed map ecu is to up the pressure on the regulator...
snake
Trainee Burger Flipper
Your car: ford
Postby Sparky on Mon Nov 25, 2002 7:14 pm
So how do I do this?
Do you think that it would be a solution to my problem, at least for a while?
Sparky
Postby snake on Mon Nov 25, 2002 8:05 pm
presume its efi turbo, take the bung outta the regulator and theirs an allen key in their, turn it, lol better off doin it with a gauge so u know what your doin.... BUT u should only adjust it on the rollers, lol
snake
Your car: ford
Postby nthorpey on Mon Nov 25, 2002 9:33 pm
clockwise :) cos its gonna be the next qustion asked :D
nthorpey
Postby Sparky on Tue Nov 26, 2002 11:02 am
Cheers snake,
nthorpey - you must have E.S.P!! :lol:
Sparky
Postby Quantum John on Tue Nov 26, 2002 2:56 pm
Sparky,
If you are going to up the fuel pressure as a way of curing the pinking it should only be regarded as a temporary fix.
If you are going to adjust it without a guage it only needs a slight turn. IIRC half a turn i.e. 180degrees is about half a bar increase in pressure. Try a quater of a turn at a time.
HTH,
John
Quantum H4 2.1 ZVH Turbo - FOR SALE
Group4 Escort MkII 2L 16v
Quantum John
Postby Sparky on Mon Dec 09, 2002 6:15 pm
My fuel pressure regulator seems to have a metal cap in the top of it. Is this where the adjustment screw is?
It looks like it might be a little tricky to get out.
Sparky
Postby nthorpey on Mon Dec 09, 2002 6:47 pm
If its never been touched before it will have the cap on as its to make it 'tamper proof' :)
This can be removed with either a small drill, screwdriver, centre punch etc whatever you've got really just be careful not to break anything but the cap !
HTH
nthorpey
