fuse blown
8 posts • Page 1 of 1
fuse blown
hi guys
im now running a 2 channel 1200w sony amp, and 2 222w 2 channel amps and my 40amp fuse has blown due to me accidental touch of the live on the body work stupid me i know, seems im running all this stuff what would you recomend a fuse i use im goin to the shop 2mra please help me thanks guys
- mattfiesta1987
I'd be cautious of using a different amp fuse for safety reasons, probably best to just stick with 40 if that was what was originally supplioed.
Beware though if it's a blade type (like under the dashboard) it'll be Bic™ to get hold of one. I recently blew one in a similar way, tried halfords as well as all local car spares shops and could only find 30A max. Had to go to Ebay in the end.....
- richard_p88
hi there went to the local audio shop and because im using all the amps on one wire from battery to a splitter they suggest a ANL fuse box and fuse, it was all calculated out for what i could potential use 1200 + 222 +222 = 1644w
and added all the fuses on the amp these came to 120 and he said i needed a 150amp fuse so he check witha a installer and he said the same so i purchased and it works fine no problems at all. the only problem i have is the interior light dim on and off.
how do i stop this problem?
- mattfiesta1987
bigger alternator mate!
150AMP fuse!!?? IMO I'd say that would be wrong. My systems main fuse uses a 25amp glass fuse and its never ever gone wrong.
And its consuming more power than 1600watt....
Formerly Jay246
- Jay
Car: 1992 Ford Fiesta RS 1800
Mate you quoted Max Power figures which are useless, i doubt you pushing out more than 500w RMS with those Sony amps
IIRC i use about a 40A anl fuse and im running 700w RMS
Using that massive fuse could result in a fire in the engine bay if theres a power surge which is not good
- diablosvy
