G reg xr2i airfilter question
5 posts • Page 1 of 1
as the idle control valve is on the airbox on my CVH ,is there anyway i can take it off and replace it with a pipercross cone,im guessing that this isnt possble as it would muck about with the way the engine runs??
- LukeGTI
You could change the idle valve for one that goes on the bulk head, Ive also known people to re-route the pipe work.
- JamieFRST
- Keep It Tidy
Lift the whole inlet manifold and Hitachi valve from a later car and add the ECU as well then drill a 2mm hole in the centre of the bottom half of the throttle butterfly. The Webber ISCV is famous for the trouble it caused
ive got 2 complete manifolds with the valve mounted to them also got the matching ecu for each as im breaking 2 xr2i's pm me an offer if ya interested
- fiestamk3.5
