Gear box swap?
11 posts • Page 1 of 1
Gear box swap?
My gear box is scrap. Can i direct swap mine with Zetec 1800 cc? Will I need Zetec clutch and ect.? Oh, my engine is 1.4 CVH CFI.
Sorry for my bad english...
- disc
Dont think so, the zetec use a Mx or MTX 75 gearbox i think (please can someone correct me if i'm wrong) and they are a pain to fit into the fiesta's apparently, i'd stick with the BC type box, but maybe go for an RS turbo box if you want a stronger one
Matt
Matt
- StreetDragster
might want to try on passionford.com or escortturbo.co.uk then mate, they will have a better idea than us fiesta owners i suspect
Matt
Matt
- StreetDragster
Depends on what kind of zetec the gearbox is from
If it is a 1.6 (90bhp)or the 1.8(105bhp) till 95 you can fit it because it is the same gearbox(bc type)
If it is a 130bhp XR3I you have a mtx gearbox and that will fit but you need another flywheel and clutch en gear lever
If the gearbox is from a escort after 95 you got a IB5 gearbox and you need to change the starter also and relocate the altenator to the back of the engine
Tell me what kind of escort(witch year) it is so i can tell you what gearbox you need
greets Tazzie
greets Tazzie
- Tazzie
Tazzie :Depends on what kind of zetec the gearbox is from
greets Tazzie
EH?!
Any iB or BC with a front-mounted starter that bolts into your enginebay the same way will fit.
You won't need to touch the clutch, flywheel or gearlever as long as the box isn't an MTX75 (and if it is, it just won't bolt in).
You can't put a starter on the back of the engine - the CVH doesn't have the right cut-outs for it.
To tell what box you have, try this: http://st2000.s5.com/ftransguide.html
Al
- Project
- fiftyoneCL
Tazzie :Uhhhhhhhhhh another thing you won't do top speed in 5th gear anymore because of the longer gear but it is less fuel consuming
greets Tazzie
Depends what power he has. If he's got enough to keep overcoming his drag, I daresay he could well get his top speed in fifth. If he's after longer gearing, I daresay he's got enough power to warrant that wish.
