gearbox cradle bolt fiesta xr2i
7 posts • Page 1 of 1
When refitting my gearbox cradle, i can't find 1 bolt
it's located at the front of the cradle, and is the upper bolt of the mount that connects the gearbox to the cradle ( black u shaped mount ) I think it has 2 diffrent sizes of thread with a spacer on it halfway
Who has a picture of it, so i can look in my spare parts or get it at a scrapyard
FORD = First On Racing Days
- Razer
- Your car: MK3 RS1800
Re: gearbox cradle bolt fiesta xr2i
Its a small spacer that goes on before the mount then a 13 mm bolt holds the mount on
I just put a box in a fez and there might be one left over if u dont get one
Unless its the one with the nut on it with blue enginneres thread on it ,if its that one then iv deffo got one ill send you but if itz the top one then its the 13mm
- mikeymikeyp
It's the one on top, the 13 mm one with a spacer between the cradle mount and gearbox.
The treadth on the gearbox side is diffrent then the one on the mounting side
- Razer
- mikeymikeyp
Hmm, i let you know tonight..now im doubting
- Razer
thats deffo it mate the other 1 or 2 thats holding the mount on are like what your thinking with a 17mm nut on one side and the other side in the gearbox ,you slide the mount on over those ones and the top one getts the spacer first then the mount then the 13mm
- mikeymikeyp
i did have it after all, only i missed the spacer.. just put a bolt between it
Many many thanks m8
Many many thanks m8
- Razer
