gearbox reverse light switch connector needed
Postby jonyb4 on Wed Jun 19, 2013 2:12 pm
i need a pigtail and connector for a BC gearbox reverse light switch, when i converted to 5 speed BC box i didnt account for needing that and is something id like to square away
let me know what you got :)
~jon
Re: gearbox reverse light switch connector needed
Postby AW0L on Wed Jun 19, 2013 7:11 pm
you got a pic Jon???
i think i got a loom for a bc box
AW0L
Postby jonyb4 on Wed Jun 19, 2013 8:09 pm
its a 3 pin triangle connection, ill get a pic :)
Postby jonyb4 on Wed Jun 19, 2013 8:18 pm
This here
Postby AW0L on Thu Jun 20, 2013 12:58 pm
i got the whole loom from a mk3 fez that connects up to the passenger side turret
pm me
AW0L
Postby mikeymikeyp on Thu Jun 20, 2013 7:10 pm
did i not send you one of those
mikeymikeyp
Postby jonyb4 on Thu Jun 20, 2013 7:25 pm
i dont believe so :P
Postby jonyb4 on Thu Jun 20, 2013 7:26 pm
mind you've sent me so much i cant tell llama
Postby sam-si on Mon Jul 08, 2013 9:33 pm
you having this reverse switch off me that i cut off the loom?>
sam-si
Your car: FORD FIESTA
Postby jonyb4 on Mon Jul 08, 2013 11:41 pm
hey sorry i got priorites atm lol, clutch has gone, and my pay is awful atm
Postby mikeymikeyp on Tue Jul 09, 2013 9:27 am
iv got a good luk clutch there jonny done like 2 track days in it id let u have it for £45 posted any less than that bud id just keep hold of it ,thats half what i paid and its mint like
just an offer if it helps :)
mikeymikeyp
Postby jonyb4 on Tue Jul 09, 2013 7:02 pm
standard clutch? whats in the box mate? cant imagine a thrust bearing also?!
im investigating the clutch tomorrow so will let you know
realized that it could be the clutch lever, its got a very low biting point so maybe its not fully engaged, either that or its leaked oil onto the plate, s the plate itself was very meaty when i split the box/engine
Postby mikeymikeyp on Tue Jul 09, 2013 9:46 pm
Take the cable off the gbox and work the arm with a lever and get someone to try the gears if its good then have a look how far the arms being pulled by the cable ,if it looks short you might be able to move the arm 1 spline and see if that helps bud
I dont know what your problem is mate
in the box ?? a plate,cover and a thrust :-?
mikeymikeyp
