Gearboxes
7 posts • Page 1 of 1
Gearboxes
Hi, Does anyone know if a Frst gearbox will fit a xr2i 16v engine?. Also would it make any difference perfomance wise over the standard xr box?, because I'm after a way of getting some extra torque without speanding loads of money.
Fords Only Run Downhill
- Jescort
Re: Gearboxes
Jescort :Hi, Does anyone know if a Frst gearbox will fit a xr2i 16v engine?. Also would it make any difference perfomance wise over the standard xr box?, because I'm after a way of getting some extra torque without speanding loads of money.
yes the gearbox will fit you wont see any difference in performance because the ratios are the same
gt 2876r aka gt25/40r roller bearing turbo, L8 ecu, 850cc injectors mapped by msd to 12psi with LC & AL closed loop 30+ psi soon
0-100 10.84 100-150 9.24 154mph daddy thrash 06
- turboboss
Re: Gearboxes
turboboss :Jescort :Hi, Does anyone know if a Frst gearbox will fit a xr2i 16v engine?. Also would it make any difference perfomance wise over the standard xr box?, because I'm after a way of getting some extra torque without speanding loads of money.
no there not.
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
Re: Gearboxes
jdfiesta :turboboss :Jescort :Hi, Does anyone know if a Frst gearbox will fit a xr2i 16v engine?. Also would it make any difference perfomance wise over the standard xr box?, because I'm after a way of getting some extra torque without speanding loads of money.
no there not.
JJ
take a look at this site.. and find out yourself
http://st2000.s5.com/ftransguide.html#gearratiosinformation
- Jur
Cheers guys. I'm going for a 1.3 5 speed box now, because a mate of mine has one on his Escort, and the ratios are different on them compaired to the 1.8 16v box, I'll give it a go and see if I blow it up.
- Jescort
Re: Gearboxes
no there not.
JJ
ok i stand corrected
- turboboss
