good spec for 300-370 (ZT)
8 posts • Page 1 of 1
this is what am planning on using?
JE PISTONS
EAGLE RODS
FOCUS RS HEAD GASKET
OBX STG2 CAMS/PULLEYS
arp bolts/nuts top to bottom
ian howells valve springs
OBX MANIFOLD
T34
CUSTOM INLET/COSSIE T/B
GREEN INJECTERS
L6
thats it, let me know what needs changing or removing?
cheers andy
JE PISTONS
EAGLE RODS
OBX MANIFOLD
T34
GREEN INJECTERS
L6
cheers andy
- andymcd
Re: good spec for 300-370 (ZT)
andymcd :this is what am planning on using?
JE PISTONS
EAGLE RODS
OBX MANIFOLD
T34
GREEN INJECTERS
L6
cheers andy
bin the obx cams and obx manifold and the green injectors and fit some astra vxr injectors cheap about £90 new for a full set and there 480cc,:D use the standard cams and one of my manifolds all prover to over 350hp.
the rest looks fine you will also need to cc the engine because when i bought that rod piston package it was ment to be 9-1 but was 10-3cr
- crazycage
when you say ian howells valve springs
do you mean uprated single or double valve springs?
- RS rob
RS rob :when you say ian howells valve springs
im still on the single ones but they have a 3mm shim under them
- crazycage
single springs, whats used to check the cc as i forgot? pm me price on your manifold gary
- andymcd
Go for Ians cams and springs imo!
- luca
only if its a silvertop engine, if its a blacktop keep the standard camsExcursion :2.0 inlet, 1.6 exhaust.
- crazycage
