GRS i/c and chargecooler
5 posts • Page 1 of 1
As i have luckily enough just got a cheap chargecooler i was wonderin if anyone has done this set up [ERRR] im interested to see how your pipe workin goes. Cheers !
- EVO
You would be best making the first cooler being the intercooler to take the chill of the ACT then pass throught the CC because it will then find it easier to then cool the cooled air.
HOWEVER i wouldnt bother, i have no problems with temps at 20psi on mine with just a EVO 3 intercooler, in fact my temps are still silly low
- Ian C70T5
- Das Ist Kapput
If you're sat in the queue at The Pod in July you might find they are not so low then...
As Ian says, intercooler first then chargecooler.
- AdrianFRST
- Baby Battle Scratch
- Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
AdrianFRST :If you're sat in the queue at The Pod in July you might find they are not so low then...
Ahh.. BUT Ade. If you are sitting in traffic getting hot, having the CC will make it worse because of heat soak. Mine suffered badly sitting in traffic and took a while to cool down once moving, where now sitting on the A14 or A1 with my IC once i start moving its instant cooling because its Air to Air.
- Ian C70T5
- Das Ist Kapput
