Guide: bleeding brakes
Postby Project on Thu May 27, 2004 4:06 am
Project
fiftyoneCL
fiftyoneCL
Postby Sams Si on Thu May 27, 2004 7:45 am
great stuff.
very useful!! :)
Sams Si
Postby snake on Thu May 27, 2004 10:35 pm
should add that u should never use the brake pedal to push brake fluid thru the system, the seals are not designed for this purpose, and with general wear and tear, u can invert the seals, or the seals will just blow out leaving u a bill for a new master cylinder..
snake
Trainee Burger Flipper
Your car: ford
Postby DaveZetec on Fri May 28, 2004 9:08 pm
good guide that!
might want to wd40 the bleed nipples up a few hours in advance, just in case. Ive never had one cease on me, but i dont look forward to it happening.
DaveZetec
Postby wywywywy on Thu Jul 08, 2004 11:25 pm
snake :should add that u should never use the brake pedal to push brake fluid thru the system, the seals are not designed for this purpose, and with general wear and tear, u can invert the seals, or the seals will just blow out leaving u a bill for a new master cylinder..
Hi, what do you mean by "push brake fluid thru the system"?
Fiesta Mk3 The Complete FAQ
Have a look, and do a search, before you ask anything :)
Project Log
wywywywy
Postby DaveZetec on Thu Jul 08, 2004 11:38 pm
he means pumping it through in order to flush the system out - basically exactly what i did when i did the brake pipes on my si 8) whoops
DaveZetec
Re: Guide: bleeding brakes
Postby dijsil on Sat Jul 25, 2009 7:58 pm
could someone reupload the guide pls ?
dijsil
Postby sikora on Sun Aug 02, 2009 12:06 am
Just buy an eezi bleed kit. I've messed about with manual bleed kits in the past but eezi bleeds are so much easier. Just attach one end to the spare wheel and the other end on top of the fluid resevoir. it'll force the fluid through automatically when you open the bleed nipple
http://www.gunson.co.uk/item.aspx?cat=674&item=1818
Cheaper on eBay i will add
sikora
Your car: XR2i, Clio Trophy
Postby pauldolman on Tue Sep 09, 2014 8:57 pm
the top link doesn't work can someone add a current link please
pauldolman
Postby Mav Singh on Fri Nov 06, 2015 12:40 pm
i used a pressure bleeder, worked brilliant well, solid brakes after.
Mav Singh
Your car: 1995 Fiesta Si 1.6
