Guide: EDIS4 schematic
Postby georgiocat on Fri Jul 24, 2009 11:17 am
Just a question...I uploaded recently a schematic about EDIS-4.I can't find it now.Did anyone from the mods or admins removed it?I had no info on this...
Thanx
George
My Ford Escort ride
georgiocat
Re: EDIS?
Postby georgiocat on Thu Jul 30, 2009 9:16 am
Anyone?It can't have deleted by it'self... :rolleyes:
My Ford Escort ride
georgiocat
Re: EDIS?
Postby georgiocat on Fri Jul 31, 2009 10:36 am
Anyway...Since I had no reply or complaints I upload it again...
Here it is:
If there is any problem with it please inform me IF someone takes it off.
Thanx
George
My Ford Escort ride
georgiocat
Re: Guide: EDIS4 schematic
Postby georgiocat on Sun Aug 09, 2009 9:41 pm
btt
My Ford Escort ride
georgiocat
Postby georgiocat on Tue Sep 08, 2009 5:53 pm
btt
Can someone from the admins move it to the Guide section because it gets lost from the other threads?I think it is good to make it sticky :)
My Ford Escort ride
georgiocat
Postby leejfiesta on Sun Oct 04, 2009 10:28 am
what does pins 1, 3, 5, 6, and 7 connect to??
cheers lee
leejfiesta
Postby georgiocat on Mon Oct 05, 2009 11:40 am
1,3 goes to ECU,5,6 goes to crankshaft sensor,and 7 is the earth that connects to the screening cable of the cablew that goes to crankshaft sensor and the ECU.If you search your wirring you will see that these 2 cables are shielded.
georgiocat
Postby FezzyGTI on Thu Oct 08, 2009 10:01 am
hi ya seem 2 understand this quitwe well would i be possible 2 run 1 of these without an ecu ??? if so how? i hav 1 layin around and am havin problems with my system on my car and could use this 2 get my car runnin so i could take it to the garage
FezzyGTI
Your car: Mk5 zetecs 2.0 ITB's
Postby georgiocat on Thu Oct 08, 2009 11:53 am
Yes you can,I've done it.It is a complete standalone system.This is the reason that you will listen very rarely that they broke down.They are very rugged design.You follow the diagram but you just don't connect anything at 1 and 3.These are the lines that go to ecu.If your engine block has a crankshaft sensor then ofcourse you can :) Of course you must have a carburetor,or else what willl you do with fuelling? :)
georgiocat
Postby FezzyGTI on Thu Oct 08, 2009 1:47 pm
Surely my ecu will deal with the fueling still? I think my problem is my ecu doesnt hav internal dis and i need 1 that does so i could use this till i get 1?
FezzyGTI
Postby georgiocat on Thu Oct 08, 2009 4:31 pm
Well,if you keep in mind that ecu does the fuelling reading info from various sensors,and just starts to squirt fuel if it reads pulseline from EDIS (pin1 of edis says ECU that you crank engine so to start injecting),I don't see why you can't.Pin 3 of EDIS is used to alter timing on ignition,but on FEZT it is not connected to ECU,only pin 1 connects ECU and EDIS.What engine-ECU have you got?
georgiocat
Postby FezzyGTI on Thu Oct 08, 2009 7:40 pm
Well not sure at min its an escort 1. I hav done a Zetec conversion and wirin loom etc and its jus not firin and i hav cum 2 conclusion its cos its wrong ecu 4 loom i hav so wanna get it runnin so i can fetch correct ecu
FezzyGTI
Postby FezzyGTI on Fri Oct 09, 2009 10:09 am
so pin 8 is positive feed 2 edis? pin 9 is earthed? plug crank sensor in and it should work???? i hav the e dis and full wirin loom so dont wanna cut owt off i need lol
FezzyGTI
Postby georgiocat on Fri Oct 09, 2009 12:14 pm
Yes,pin 8 goes to ignition +12V, and 9 goes to earth.Considering your coils work fine,when you plug the crank sensor and turn the engine,you will have spark.
georgiocat
Postby FezzyGTI on Fri Oct 09, 2009 2:56 pm
[quote="georgiocat"]Yes,pin 8 goes to ignition +12V, and 9 goes to earth.Considering your coils work fine,when you plug the crank sensor and turn the engine,you will have spark.[/quote]
yeah it should if not i got a couple of spare coils knockin around, so wot do pins 2 4 11 do then??? jus curious
FezzyGTI
Postby FezzyGTI on Fri Oct 09, 2009 7:17 pm
Does crank sensor effect fueling? Via ecu?
FezzyGTI
Postby georgiocat on Fri Oct 09, 2009 7:21 pm
Yes m8,at external edis ecu understands when to fire the injectors by receiving pulses from pip,this is pin 1 from edis that go to ecu.It will give pulse,if the edis reads pulse from the crank sensor,so indirectly yes,ecu is affected by crank sensor.
georgiocat
Postby FezzyGTI on Fri Oct 09, 2009 8:25 pm
Thought so. Do ya kno which pin it goes 2 on the ecu? If not think i got a plan 2 sort it
FezzyGTI
Postby FezzyGTI on Sat Oct 10, 2009 4:52 pm
My ecu is a 2FCD
FezzyGTI
Postby FezzyGTI on Thu Oct 29, 2009 2:23 pm
Could ya tell me which pin numbers on ecu pip and saw go 2?
FezzyGTI
Postby pottis on Wed Dec 01, 2010 10:44 am
A very useful guide to a schematic about EDIS-4 and especially with the diagram, I am sure this will help a lot of people to understand all about the Ignition System and with the doubts and questions raised here, it’s clear that it is helping them to really understand it better!!
pottis
Postby andymac on Tue May 03, 2011 6:07 pm
That will be very useful later this year, thanks !
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
Postby georgiocat on Wed May 18, 2011 10:58 am
I am glad that it is helpfull.Truth is that EDIS is well-known and it's schematic is to all electrical Ford manuals,but this is more crear to read,and is isolated from the rest circuitry...
georgiocat
