Guide:OFAB Loom management pinout and plugs
Postby georgiocat on Tue Jul 14, 2009 2:16 pm
Here I have some info on OFAB mamangement.This is part of the info I used for the FEZT engine transplant in my MK5b Escort.Since I gather technical staff for ages now,I can't be sure where I found this,but obviously the opyright goes to the author,it is not mine just to be clear.It helped me a lot and hope to do the same with other people.If the admins want they can move it to the relevant section of the forum.Thanx.
Loom:
Loom plugs:
George
My Ford Escort ride
georgiocat
Re: Guide:OFAB Loom management pinout and plugs
Postby georgiocat on Wed Sep 30, 2009 9:57 am
I have to clear out after some search that the schematics on Haynes manual,and autodata,that I have personally checked numberous times when I was converting my car,is for the OFAC,so if you are converting to,or checking OFAB layout you must follow this guide,not the guide in Haynes or autodata.I have also TIS guide but is is a pain in the a@@e to follow it,and as everybody who worked on wirring knows,when you do that kind of work you need a clear and easy to read schematic...
georgiocat
Postby FezzyGTI on Thu Oct 29, 2009 5:57 pm
what is ofab ??? eg what type of engine is it for?
FezzyGTI
Your car: Mk5 zetecs 2.0 ITB's
Postby georgiocat on Tue Nov 03, 2009 12:22 am
OFAB is one of the 3 types of management for the Fiesta turbo.OFAA was the first one,OFAB the second release from Ford which was based on the marelli map sensor,and OFAC being the last one which used the classic rectangular ford map sensor.It was on CVH engines,but can work on zetec turbos,although not sure on what needed for the conversion on a zetec since I never did it.
georgiocat
Postby TANGO. on Tue Nov 03, 2009 12:41 am
giorgio do you have any diagrams for the 12 pin car loom, grey colour at the back of the bay?
many thanks
wayne
TANGO.
Postby FezzyGTI on Tue Nov 03, 2009 2:05 am
[quote="vauxhallscum"]giorgio do you have any diagrams for the 12 pin car loom, grey colour at the back of the bay?
many thanks
wayne[/quote]
i would like this 2 plz if possible cheers 4 info
FezzyGTI
Postby georgiocat on Tue Nov 03, 2009 1:07 pm
No my friend,I am sorry I haven't...
georgiocat
Postby TANGO. on Tue Nov 03, 2009 6:40 pm
ok no worries dude, just needed to know what each of the brown wires are!!!!
TANGO.
Postby georgiocat on Fri Nov 06, 2009 11:03 am
If they are just plain brown ones,I mean no color trace on them,they usually are current return,ground.
georgiocat
Postby FezzyGTI on Fri Nov 06, 2009 7:50 pm
[quote="vauxhallscum"]ok no worries dude, just needed to know what each of the brown wires are!!!![/quote]
I can show you 2 photo of the plug they go to on the loom inside the car. They go 2 a plug wi about 24 plain brown wire's in i hav the in car loom for a si in my bed room so traced them 2 try figure it out 4 my project.
FezzyGTI
Postby TANGO. on Sat Nov 07, 2009 11:20 am
that would be great mate nice one!!
I dont think it makes a difference which wire they go to as long as its another brown, would be nice to know for deffo though
TANGO.
Postby FezzyGTI on Sat Nov 07, 2009 5:22 pm
Ok no prob's when i get home i will take a few photo's and post them up hope it helps. Not sure if its same for si loom as for this loom but i would of thought it is?
FezzyGTI
Postby FezzyGTI on Mon Nov 09, 2009 4:57 pm
do ya mean this plug?
if so pins 12 and 7 (bown wires twisted together further in 2 loom) pin 8 brown wire on its own goes in 2 fuse box 2 many wire 2 see where it links 2 tho. pin 1 also brown wire joins 2 sum more brown wires looks like an earth
[IMG]http://i791.photobucket.com/albums/yy198/Nafrival/DSC07320.jpg[/IMG]
http://i791.photobucket.com/albums/yy19 ... C07320.jpg
they go 2 pins 1 and 14 on this plug
[IMG]http://i791.photobucket.com/albums/yy198/Nafrival/DSC07321.jpg[/IMG]
http://i791.photobucket.com/albums/yy19 ... C07321.jpg
hope sum of this helps
the images dint wrk so put links aswell
FezzyGTI
Postby mikeymikeyp on Sat May 14, 2011 10:11 pm
sorry to post on an old thread but i was hoping someone had a idea where the 12 pin plug as in pic above joins to the 8 pin plug on ofac/ofab engine loom
thanks guys i do really need a bit of help here
mikeymikeyp
Postby georgiocat on Wed May 18, 2011 10:54 am
Sorry m8,just saw your post...I believe your question is allready being answered by someone if I am not mistaken...
georgiocat
Postby mikeymikeyp on Thu May 19, 2011 8:26 am
thanks for the reply mate I found what i was looking for and posted it up
mikeymikeyp
Postby georgiocat on Wed May 25, 2011 11:59 am
Sorry not to be so helpfull regarding your issue,but since I own an Escort and not a Fiesta,I couldn't help you really on that... :)
georgiocat
Postby Lee jst on Tue Dec 09, 2014 12:21 am
Can anyone tell me if there is much difference between this ofab wiring diagram and the wiring for a ofac loom?
Thanks lee
Lee jst
Your car: K plate fiesta rs turbo
Postby s1chris on Sun Dec 14, 2014 6:33 pm
Hi Lee,
Check this thread out as it may answer your question -
efi-ofab-ofac-differences-are-a-internet-myth-discus-vt65850/
Cheers Chris
s1chris
Postby Lee jst on Mon Dec 15, 2014 11:34 pm
Thanks for the link to that Chris intresting bit of info there
Lee jst
Postby 90_Spec on Wed Nov 07, 2018 5:02 pm
HI All,
I know this is an old thread now, but im running into the same confusion over it all.
Did anyone actually get tot he bottom of the OFAB / OFAC co pot/ MAP pinouts? i know there is a lot of opinion out there, but can anyone say, "YES" there are variations of OFAB where the CO pot and MAP are in different pin numbers to the conventional conversion guide ... those being CO pot signal on pin 8 and MAP signal on pin 27?
Also, does anyone know what the output voltage / signal voltage from the CO pot should be for a standard setup?
Hope you can all help,
Cheers, Rich
90_Spec
Your car: BMW 535D
